For those of you that have saftey wired your Hyper... - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 3rd, 2010, 1:05 am   #1 (permalink)
richmeyer's Avatar
...How in the world did you wire the front axle pinch bolts? On my 996 they are an exposed bolt, on the Hype they are recessed allen heads. Is there some sort of replacement bolt I can use?
WMRRA #621
2000 996
2010 SFS
Ducati Bellevue
Darren Beatty Photography
MOTOWHEELS
AMSOIL
Spy Optic
Mountain Khakis
richmeyer is offline   Reply With Quote
Old Nov 3rd, 2010, 2:13 am   #2 (permalink)
Decreasing Dave's Avatar
Images: 14
Are you racing it, or just for a trackday??
I ask because I had an R6 that I raced with CCS and never had to wire the calibers or the axle bolts. Just stuff with fluids behind them.
I know the AMA requires more than CCS ever did but most trackday organizations do not require much at all.
You might want to check into the EXACT requirements before you go through all the trouble, if you haven't already, of course.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Nov 3rd, 2010, 4:47 am   #3 (permalink)
Luckystrike's Avatar
My 848 is the same way, I just don't wire them and tech doesn't even see them. If you're worried about them, a dab of silicone will be fine.
Luckystrike is offline   Reply With Quote
Old Nov 3rd, 2010, 8:58 am   #4 (permalink)
Silicone should work ok.
But if you really want to wire them, they can be done!
(I'll save your screen space and not put my last 20 bikes here)
yellow cake is offline   Reply With Quote
Old Nov 3rd, 2010, 9:44 am   #5 (permalink)
Varmitcong's Avatar
Rich, I replaced mine with some SS ones that have a slightly taller crown. I believe they are a few mm longer too, so I installed one of those black hard plastic washers (Zytel?) so that it would stand away from the fork a little more. It is the best that I could come up with. Torqued them then wired them with no problems.
I've wondered if those Ti bolts with the tall crown would work too.
CHEEKRASHSUCKS!
Varmitcong is offline   Reply With Quote
Old Nov 3rd, 2010, 11:04 am   #6 (permalink)
richmeyer's Avatar
Thanks guys, If I do wire it, it will be for racing. Ever since I saw the vid of that Canadian guy racing one Ive had a bug to do it. I dont really ride it on the street anymore so I might as well punish it on the track. WMRRA requires them to be wired, and I've got to wire the axle bolt too. The pinch bolt works well to wire the axle bolt to. Thanks again!
WMRRA #621
2000 996
2010 SFS
Ducati Bellevue
MOTOWHEELS
AMSOIL
Spy Optic
Mountain Khakis
Old Nov 3rd, 2010, 12:22 pm   #7 (permalink)
lelenb's Avatar
Images: 12
Be careful with those stainless fasteners in aluminum due to strong galvanic corrosion. Aluminum hates stainless steel fasteners. I work with packaging equipment and see this on a daily basis. The aluminum always loses.
Lelen
Hyper S
Old Nov 3rd, 2010, 12:26 pm   #8 (permalink)
Banned
It's annoying but not horrible difficult, you can drill through a bit of the fork leg and then angle into the head of the bolt or carefully just angle into the bolt (drill presses rock for this) and it'll be enough of a hole to slide wire through.
The easiest if of course a bolt with a taller head or go the bicycle clamp route.
Old Nov 3rd, 2010, 12:50 pm   #9 (permalink)
2008 Hyper (Street/Track)
2008 848 (Race)
Old Nov 3rd, 2010, 1:10 pm   #10 (permalink)
Banned
Popular mod for endurance racing, you use a bicycle axle with the flip up lever in place of the pinch bolts. Not as tight as pinch bolts but functional enough for racing and speeds up tire changes.
Hyper 796 or refinish the garage? -> the Hyper won! spindrift Welcome and Introduction 5 Jul 14th, 2010 1:17 am
wired oil Plug JCPakBikes Superbikes 0 May 10th, 2008 2:38 pm
Wired Coil ? ZDM Superbikes 2 Jan 19th, 2008 2:59 pm
wired V-1 on 999 karlb Superbikes 10 Dec 23rd, 2007 7:02 pm
Saftey Wire photos please DesmolitonMan Ducati Motorcycle Chat 47 Oct 26th, 2007 11:55 am
