Front Shake/Vibration when Braking.. Very Wierd! - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 2nd, 2010, 2:36 am   #1 (permalink)
When I come almost to a stop, the whole front begins to shake on my HyperMotard 796 2010 . It only has 400 miles on it, could this be part of the brakes breaking in, or do I have another issue.. Its very wierd. The whole front goes into an awkward shake right before coming to a stop at RANDOM times.. I think my brake fluid may be slightly low??
rambino is offline   Reply With Quote
Old Nov 2nd, 2010, 3:16 am   #2 (permalink)
Decreasing Dave's Avatar
Images: 14
Keith Code says that nothing that happens to a motorcycle at "random times" is the motocycles fault.
What he means is that it is a machine and will do EVERYTHING consistently unless an outside source is introduced to the situation.
Things to look at when the action happens:
-traction issues
-air pressure in tires
-brake fluid level
-brake lever consistency
-intesity of braking
-body positioning
-loaded weight of motorcycle
-suspension set-up
....just to name a few.....
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Nov 2nd, 2010, 3:39 am   #3 (permalink)
johnchypermotard's Avatar
as always, decreasing dave makes excellent points ... but he did leave out a few potential causes for this random braking issue you mention:
  • gravitational pull of the moon
  • time of month for your cycle
  • bad gas (either in the bike's tank, and/or your's)
  • the giants winning the series
-traction issues
-brake fluid level
-body positioning
-suspension set-up
Dave
Old Nov 2nd, 2010, 9:01 am   #4 (permalink)
Low brake fluid? How in the hell could it cause any shake???
Look into tire pressure, and wether the suspension is set for your weight.
Z0RR0 is offline   Reply With Quote
Old Nov 2nd, 2010, 9:34 am   #5 (permalink)
If you can rule out rider input, it might be warped rotors or loose head bearings as well. When braking, make an effort to keep your hands and arms loose (no death grip on the bars or locked elbows)... to do this grip the tank with your knees to support yourself.
There's a chance you are causing the front-end to wobble or shake due to fighting the front end's natural tendency to move around a little bit on hard braking. If it's still doing it with a light grip on the bars and loose elbows/arms you should have the head bearings checked for tightness and also inspect the rotors for any warpage.
'11 Hypermotard 1100 Evo
'03 DRZ400E, converted to SM
Darren is online now   Reply With Quote
Old Nov 2nd, 2010, 9:57 am   #6 (permalink)
bromike666's Avatar
My 2005 Multi had the "death shake", and it's f'ing scary. It was a known issue on the early Multistradas. Shop sanded my pads, replaced a few bolts and it never happened again.
"I love the sound of a dry clutch in the morning"
10 F1098S Streetfighter
08 Hypermotard 1100S
08 Multistrada 1100S
07 SM610
bromike666 is offline   Reply With Quote
Old Nov 2nd, 2010, 10:16 am   #7 (permalink)
08hyper's Avatar
You have warped rotors or loose rotor bolts, maybe even the rotors not bolted down flat, have them checked ASAP Aloha Alex
Old Nov 2nd, 2010, 10:20 am   #8 (permalink)
Motoman_AZ's Avatar
Originally Posted by darren View Post
if you can rule out rider input, it might be warped rotors or loose head bearings as well. When braking, make an effort to keep your hands and arms loose (no death grip on the bars or locked elbows)... To do this grip the tank with your knees to support yourself.
+1
Greg aka Motoman
www.emotoman.com
2009 Duc Hyper S
2006 Honda CRF50
2005 Suzuki LTZ-400
2005 Honda CRF450x
2003 Yamaha YZ250F
1993 Sportster Hybrid
1977 Kawasaki KZ650
Motoman_AZ is offline   Reply With Quote
Old Nov 2nd, 2010, 10:23 am   #9 (permalink)
Moderator
stryder's Avatar
I'd be interested in finding out which bolts they replaced. Are you speaking about the brake union bolts with wider holes?
Ducati ST bikes as well as superbikes also report the same issue, as do other marques/models. There are all types of posts on this subject and all types of theories. I have read several and am of the opinion that it's a material transfer issue, compounded by a bedding-in issue. My guess is you didn't bed your pads in properly and they're glazed. My ST started to judder severely only this year, approx 21K miles, but not all the time. It may come and go in the same ride. I'm NOT going to swap the pads out in order to eliminate a possibility that the pad material has "strata" in them, which causes material transfer more easily than at other times in their wear pattern. Time will tell.
Another theory, which may help explain why this issue is not specific to any one Ducati model or to Ducati, is that bikes with upsidedown forks are more prone to this type of brake juddering issue due to flex in the sliders, since no bracing can be used. Makes sense to me.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
Old Nov 2nd, 2010, 11:17 am   #10 (permalink)
I had the same issue on my FZ6-N.
Under braking, the front end would randomly start to shake very bad.
It would happen when braking at high speed or low speed, in town.
The shacking was so bad, I decided to sell the bike but wanted to get the thing fixed before selling it.
Took it to my Yam dealer, gave me a R6 for the day (which I bougth at the end of the day) and solve the damn shacking issue.
The rotors were not wrapped at all.
He eventually figured out that thhose little guys (in red on this picture... which english name is unknown to me - les douilles en francais, qui tiennent la piste et la frette) were so tight the disc was not floating anymore.
Toc sound on hard front braking? joeracing1 HyperMotard 12 Jun 17th, 2010 7:46 pm
Front wheel hopping under extreme braking? JohnMH Superbikes 14 Nov 24th, 2009 3:52 pm
do you have-Braking, Galfer wavy discs front? sinex HyperMotard 9 Feb 8th, 2009 9:44 am
Braking Directional STX front rotors cuvi Supersport 0 Oct 17th, 2008 12:10 pm
Vibrating front suspension whilst braking Joris Sport Touring 42 May 12th, 2008 10:37 pm
