Airbox Blanket?!?!? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Oct 26th, 2010, 10:02 am   #1 (permalink)
Airbox Blanket?!?!?
Finally recieved my Termignoni exhaust.
Whats the deal with the blanket on top of the airbox?
Is it really needed?
thanks in advance
crackerr
Crackerr is offline   Reply With Quote
Old Oct 26th, 2010, 10:18 am   #2 (permalink)
el tardo's Avatar
im not sure, when i did my air box mod i just cut around the filter area and put it back in.my guess is so things dont rub and get messed up?
2010 black 796
dont make me badge you!!
el tardo is online now   Reply With Quote
Old Oct 26th, 2010, 12:14 pm   #3 (permalink)
08hyper's Avatar
Banket? what blanket? maybe for noise control? (yours) Aloha Alex
Old Oct 26th, 2010, 12:50 pm   #4 (permalink)
johnchypermotard's Avatar
alex,
i am guessing that later production model hypertards have been delivered with an airbox blanket ... as our first year models did not come with these. i am guessing that these were added later on after intro, to help pass EU noise emission testing.
i have seen these blankets listed on fleaybay as being parted out from wrecked hypertards.
can't be a safety issue, as i am certain ducati would have issued a factory service bulletin on this if it were.
Old Oct 26th, 2010, 1:05 pm   #5 (permalink)
Abarth's Avatar
I think you mean this blanket? (bottom right picture).
I couldn't find it on my Hyper either. (08 model).
---===[ 2008 Ducati Hypermotard 1100S (110,3 DIN RWHP) ]===---
|Modifications|
Termignoni 2 in 1 Full Exhaust System, Flowed Cylinder Heads, DP Race Cams, DP Race ECU (Reflashed for Wasp Kit), Wasp Power Up Kit, NGK Iridium Spark Plugs, Ducati Biggelaar Quiet Clutch modification, Lightweight flywheel (700 gram), DP Clutchplate, Carbon Clutchcover, DP Racing Seat, DP Oil Plug, Rizoma Grips, Rizoma Brake/Clutch Reservoirs, Rizoma Rear Blinkers, Painted Racing Stripes, DP Carbon Mudguard, HK Suspension Upgrade, Bitubo Steering Damper, STM Oil Breather, GiPro Gear Indicator, DP Clutch Slave, DesmoWorld Frame and Seat Plugs
Abarth is offline   Reply With Quote
Old Oct 26th, 2010, 1:36 pm   #6 (permalink)
Monstaman's Avatar
It is just a noise emissions, nothing more than that, get rid of it.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Oct 26th, 2010, 1:40 pm   #7 (permalink)
NikMusolino's Avatar
Mi '09 S used to have that felt fürshür... then smartly swapped for Ducshop stacks.
'09 HYM1100S Nero
Old Oct 26th, 2010, 4:18 pm   #8 (permalink)
merovingian's Avatar
Dont think its a Model year thing my 08 had the blanket, now gone also due to wasp stacks
Edit
You can see it here:
I cant see how it would work for emissions, I assumed it was to protect the tank from plastic-plastic contact with the air box
merovingian is offline   Reply With Quote
Old Oct 26th, 2010, 4:19 pm   #9 (permalink)
maybe my 2007 model year hypertard was the only one that didn't get this security blanket ...
Old Oct 26th, 2010, 4:20 pm   #10 (permalink)
minusone's Avatar
my 08 model did not have one
my 09 model had one - now removed
Airbox mod on 796??? cpike HyperMotard 11 Oct 29th, 2011 8:55 pm
K&N w/out airbox mod? pasophisto Supersport 9 Jun 30th, 2008 5:02 am
DP Airbox Lid MDMason HyperMotard 38 Mar 7th, 2008 4:01 pm
CF airbox the-duc-master Superbikes 8 Mar 10th, 2007 3:12 pm
