Trouble Starting this Morning.... - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Oct 22nd, 2010, 10:36 am   #1 (permalink)
Do ducs have an issue starting up when its really humid outside? Today was the most humid its been since a bought it a few weeks back. It started but wouldn't stay on. I had to rev it a little to really get it going and stay on. Once it was on, it ran fine. Info would be helpful, thanks!
HyperFern is offline   Reply With Quote
Old Oct 22nd, 2010, 10:51 am   #2 (permalink)
yabo0569's Avatar
Yeap that is normal, a race Ecu can help in the mornings since the engine is receiving more fuel.
yabo0569 is offline   Reply With Quote
Old Oct 22nd, 2010, 11:01 am   #3 (permalink)
I bought the bike used with a full termi system on it. Not sure what all was done to it. There's an ECU box in all the stock stuff that the original owner gave to me.
Old Oct 22nd, 2010, 11:06 am   #4 (permalink)
el tardo's Avatar
check you plugs for carbon or fuel build up.they might need to be changed
iridium plugs last longer and stay cleaner which helps with better starting.
iridium plugs dont add more power or more spark,the iridium tip gets hotter then a normal plug which is why its called a self cleaning plug.it wont foul as quick and will last longer,less build up of carbon.
worth the money!
and fyi if you have normal starting issues with a v-twin your TB sync or TPS might be off .its the most common problem
2010 black 796
dont make me badge you!!
el tardo is online now   Reply With Quote
Old Oct 22nd, 2010, 11:11 am   #5 (permalink)
Will do! Would I really need plugs so soon? It's an 08 but only had 1400 miles when I bought it. Has 1900 on it now.
Old Oct 22nd, 2010, 11:19 am   #6 (permalink)
el tardo's Avatar
a plug can foul very easy and stock copper plugs are very cheap . its just a guess , only way to tell is pull your plugs,very easy to do.motorcycles eat plugs much faster then cars. look for any rounding of the electrode,carbon build up or blackening from to much un burnt fuel
2010 black 796
Old Oct 22nd, 2010, 11:48 am   #7 (permalink)
johnchypermotard's Avatar
if replacing the plugs does not work ... try pouring an espresso in the fuel tank.
since it's an italian bike, it needs an espresso in the morning to get going
Old Oct 22nd, 2010, 2:15 pm   #8 (permalink)
shanetbird's Avatar
hard starting
went all though this , now got improved wiring cable to starter and battery
mine was more in the cold but live in the tropics
i good dyno tuner will have it singing
these engines are worst than the old bevels need constant loving
fixed my hard starting
shanetbird is offline   Reply With Quote
Starting Trouble, Please Help! Gemcoska Superbikes 9 Feb 10th, 2009 12:39 pm
Trouble starting '03 999 jason Superbikes 14 Jan 27th, 2009 12:44 pm
Trouble starting my PS -- what do I need? localmotion411 Sport Classic 4 Sep 8th, 2008 8:53 pm
Trouble starting? JDuc Monster 0 Apr 3rd, 2007 7:22 am
Trouble starting atomic-jl Supersport 5 Nov 14th, 2006 6:37 am
