HM wiring harness defect - Ducati.ms - The Ultimate Ducati Forum
Old Oct 11th, 2010, 10:22 pm   #1 (permalink)
Well, it isn't exactly a defect in the wiring harness, but i was riding the HM popped a minor wheelie and when I came down the bike suddenly went dead. I pulled over on the side of the road to check the fuses and sure enough the 30 amp fuse underneath the seat was fried. I tried the spare and it blew too, but the good news is that I saw the short...the seat bracket had sliced into the wiring harness, until it was shorting out. Got a extra 30 amp fuse and made it home..luckily, by wrapping the cut with plastic bags that I found on the side of the road. It is now safely wrapped with tape, but it seems like a stupid design defect from Ducati to put the wiring harness/seat bracket in a position that would cause such damage. Beware....
09 Hyper S
910R Brutale
XR750 Harley
WR400F Yamaha
CodeRed is offline   Reply With Quote
Old Oct 11th, 2010, 11:06 pm   #2 (permalink)
Gilly's Avatar
Images: 17
If that's the manner in which the wiring is put on the bike at the factory, it's definitely worth a call to the dealer. Does it look like it should have been zip tied secure or the manner in which it was threaded through the bracket?
"Oh My!" thread link... FFS!
Old Oct 12th, 2010, 9:01 am   #3 (permalink)
The wiring harness is underneath the seat bracket, when pressure is put on the bracket by seating on the seat, the sharp edges of the seat bracket slice into the wiring harness...
09 Hyper S
910R Brutale
XR750 Harley
WR400F Yamaha
Old Oct 12th, 2010, 10:42 am   #4 (permalink)
You wouldn't happen to have a picture or two would ya?
I'm looking under my seat and I don't see much like you're describing.
2009 Hypermotard 1100 S
2008 Aprilia SXV 550
hyper.s is offline   Reply With Quote
Old Oct 12th, 2010, 3:34 pm   #5 (permalink)
joeR6's Avatar
I think I know what you are talking about. The bracket directly under the seat that has two rubber stubs on it and surrounds the gas tank (at least on the CCW HM 69 gas tank.) The wiring harness goes from one end of the bike the other lengthwise and runs along the gas tank, under the seat and under the bracket in question. This bracket has some sharp edges that can pinch the wiring harness and over time might cut into the wiring harness causing a short.
Easy fix is to put some rubber padding in b/w the bracket and wiring harness. The CCW tank came with some extra rubber paddding for this purpose. I also wrapped the wiring harness with some electrical tape (just the section that goes underneath the bracket) for good measure.
09 Hyper 1100
06 Yamaha FJR1300 (sold)
04 Yamaha R6 (sold)
joeR6 is offline   Reply With Quote
Old Oct 12th, 2010, 4:50 pm   #6 (permalink)
el tardo's Avatar
mine looked fine when i did the air box mod but will check again to make sure-good heads up!
2010 black 796
dont make me badge you!!
el tardo is online now   Reply With Quote
Old Oct 12th, 2010, 5:21 pm   #7 (permalink)
AXE
AXE's Avatar
Yeah, over the last few years a handful of people have reported this issue. For the most part, everything turns out OK. However, I think a couple of people had the issue in heavy traffic and that would make things very unsafe. It's worth a check to make sure you ain't rubbing.
Out!
2008 Ducati Hypermotard
Old Oct 12th, 2010, 5:52 pm   #8 (permalink)
^ Exactly!
09 Hyper S
910R Brutale
XR750 Harley
WR400F Yamaha
Old Oct 20th, 2010, 8:43 pm   #9 (permalink)
doon's Avatar
Had my seat off today and looked at my seat retaining bracket.
It has a rubber gasket to protect the wires for this very reason, are you sure somebody didnt put it back after f@#king with it
doon is offline   Reply With Quote
Old Oct 21st, 2010, 10:45 am   #10 (permalink)
Banned
Had generally the same thing happen but it was my issue with not protecting the bracket edge more after installing the big tank. Couple of pieces of fuel line sliced so they slide over the edges and no more issues.
WTB: 998 Wiring Harness corsemoto Parts and Accessories 0 Mar 12th, 2010 10:02 am
wiring harness the same - 06 999R vs 03 999? JohnMH Superbikes 0 Aug 26th, 2009 8:12 am
wiring harness for 998 guydingdave Superbikes 2 Jun 17th, 2009 7:34 pm
wiring harness? rashmaster Superbikes 6 Sep 29th, 2008 11:11 pm
Will 05 999 wiring harness Fit 03 999 backofthepack Superbikes 1 Sep 13th, 2008 9:57 pm
