DP cams - Ducati.ms - The Ultimate Ducati Forum
Old Oct 11th, 2010, 7:34 am   #1 (permalink)
Question DP cams
Do you know if the cams Part number : 14812441B and 14812451B are the same as in the HM cam kit c/w ECU part number:96451008B.
I would like to buy the cams but not the ECU, and if they are the same, i can tell you that the price of the Cam ECU in the kit is : $463.00 too much for a fixe ECU in my mind.
Motorcycle Maniac
10 Ducati Streetfighter
08 Ducati Hypermotard
08 Aprilia SXV-550
10 Gas Gas TXT280 Pro
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
shwantz34 is offline   Reply With Quote
Old Oct 11th, 2010, 9:30 am   #2 (permalink)
08hyper's Avatar
Back in 08 the cams kit was the cheapest way to get the DP ECU
I used the cams ECU for a year before installing the cams
I do believe that the PC's work better on the DP ECU as they are a open loop system and you will not get any dash codes, the stock ECU is a closed system.
The DP cams ECU can handle about 90% of all the mods out there. Aloha Alex
Old Oct 11th, 2010, 11:56 am   #3 (permalink)
Cams are same or not ?
Thank's Alex, but i prefer to put the $463.00 saving on a Microtech( if the cams are the same as in the cam Kit) and be able to tweak it myself , than be dependant from a Ducati shop that doesn't know what they have to do with the DP ECU if not right.Also the DP ECU seems to be very limited in what parameter you can change on it.
So does the cams are the same or not ?
Somebody know ?
Motorcycle Maniac
08 Aprilia SXV-550
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Old Oct 11th, 2010, 6:22 pm   #4 (permalink)
desmolvr's Avatar
In the past the only way to get the cams was to purchase the whole package. You may also post up that you just want to purchase the cams and someone like Alex may have them after installing only the ecu.
Check out Commonwealth Motorcycles Ducati & Triumph OEM Parts, Performance Accessories & Apparel they list the cams by them selves. You might also check with the ducshop as they have a great deal on the microtech ecu.
desmolvr is online now   Reply With Quote
Old Oct 11th, 2010, 6:50 pm   #5 (permalink)
Official Sponsor
desmoworks's Avatar
These cams: Ducati 1000/1100 DS Racing Camshafts (99721) | ducati parts, ducati clothes and ducati OEM -$752.80 for the pair.
Are the same that are in this cam kit: Ducati Hypermotard 1100/1100S Racing Camshafts (96451008B) | ducati parts, ducati clothes and -$828.80 for the kit.
For a $76 difference it makes more sense to get the cam kit and then sell the ECU for $200 or so.
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is online now   Reply With Quote
Old Oct 11th, 2010, 9:29 pm   #6 (permalink)
Thumbs up
I check back, and your absolutely right, its $365.50 each and not for the set( like i was thinking).
So the cam kit c/w ECU is a no brainer, if it doesn't fit my set up i'll sold it then.It worth trying it for sure.
Thank's to all !
Motorcycle Maniac
08 Aprilia SXV-550
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Wanted Ducati ST2 CAMS OR 900 CAMS SURVEYOR Parts and Accessories 0 Feb 11th, 2010 1:56 am
anyone run the cam euc without cams testa HyperMotard 6 Sep 9th, 2009 8:26 pm
749R Cams vs. 999R Cams ??? SittingDuc Superbikes 4 Aug 14th, 2009 11:55 pm
Inj.cams v carb. cams ambi Supersport 4 Apr 21st, 2008 6:44 pm
SPS cams the-duc-master Superbikes 3 Mar 7th, 2007 2:48 am
