'10 dash in '08-'09? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 9th, 2010, 6:37 pm   #1 (permalink)
Pretty much all in the title.
What can be done to retrofit a sleek '10 dash into an earlier HM? If at all possible ...
Z0RR0 is offline   Reply With Quote
Old Oct 10th, 2010, 12:47 am   #2 (permalink)
if you find one on ebay, probably have to get the dealer to do some programming, if even possible.
nikkihyperr is offline   Reply With Quote
Old Oct 13th, 2010, 7:38 am   #3 (permalink)
kaloo's Avatar
First, a second hand dash is coded.
Second, the EVO use an ECU Siemens, the earlier model use a M-M ECU so I think it's not possible.
kaloo is offline   Reply With Quote
Old Oct 13th, 2010, 8:33 am   #4 (permalink)
Why would you? The old dash is pretty much the same as the new dash and better visible on a bright summer day, and in the dark the new dash is to bright.(old 1100 vs new 796)
ex-tuononono is offline   Reply With Quote
Old Oct 13th, 2010, 11:06 am   #5 (permalink)
Fin_Duc's Avatar
Originally Posted by ex-tuononono View Post
...and in the dark the new dash is to bright.(old 1100 vs new 796)
The new one has 3 different brightness levels..
2010 Dark HM796 w. SC-Project slipon, LV cat elim. and PCV = FUN!!!
Originally Posted by 1badduck View Post
My hyper brings out the hooligan in my hooligan.
Fin_Duc is offline   Reply With Quote
Old Oct 13th, 2010, 1:21 pm   #6 (permalink)
It was just a thinking out loud stuff, but I do like the design of the newer one more. kaloo makes a good point ... different CPUs most likely mean no compatibility.
Old Oct 14th, 2010, 12:14 am   #7 (permalink)
Ask Jo if he would let you borrow his 796 dash...
Anyway, for the price of a new dash, you might aswell try to fit a AIM MXL dash.
Old Oct 14th, 2010, 5:46 am   #8 (permalink)
Abarth's Avatar
And don't forget the mileage on your Hyper will be reset to 0 since this is stored in the dash.
---===[ 2008 Ducati Hypermotard 1100S (110,3 DIN RWHP) ]===---
|Modifications|
Termignoni 2 in 1 Full Exhaust System, Flowed Cylinder Heads, DP Race Cams, DP Race ECU (Reflashed for Wasp Kit), Wasp Power Up Kit, NGK Iridium Spark Plugs, Ducati Biggelaar Quiet Clutch modification, Lightweight flywheel (700 gram), DP Clutchplate, Carbon Clutchcover, DP Racing Seat, DP Oil Plug, Rizoma Grips, Rizoma Brake/Clutch Reservoirs, Rizoma Rear Blinkers, Painted Racing Stripes, DP Carbon Mudguard, HK Suspension Upgrade, Bitubo Steering Damper, STM Oil Breather, GiPro Gear Indicator, DP Clutch Slave, DesmoWorld Frame and Seat Plugs
Abarth is offline   Reply With Quote
Old Oct 14th, 2010, 5:53 am   #9 (permalink)
Hey Zorro have you bought an HM
Hey Zorro have you bought an HM ?
If so witch model do you have ?
Any pictures?
Motorcycle Maniac
10 Ducati Streetfighter
08 Aprilia SXV-550
10 Gas Gas TXT280 Pro
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
shwantz34 is offline   Reply With Quote
Old Oct 14th, 2010, 8:43 am   #10 (permalink)
Not yet, still debating between a few different models ... most of which you're already familiar with, actually! HM, 1098, SXV (I know you're gonna say "bad idea for the street" hahaha), Super Duke ... managed to sort of rule out the Streetfighter because I didn't like its looks enough.
Aiming for a 1098 lately ... if you hear of any good deals drop me a PM. There's one in Cowansville that's been on lespac for a while ... not bad at 12,5k (asking price), but compared to 9-10k in the US (usually with goodies, too) ... not sure if the hassle of importing a bike is worth 3k.
Will probably at least go and check it out over the weekend. Another one in Gatineau ... and then a bunch @14k.
DP ecu changed my dash to kms. weld86 Sport Touring 6 Apr 22nd, 2011 12:11 am
replacing dash on 848 , how to reset ecu or new dash? RACERX901 Superbikes 3 Apr 24th, 2010 3:54 pm
Red led on dash of ST2 Thanas Sport Touring 18 Mar 7th, 2009 11:53 pm
I got something in the dash keljose Superbikes 11 Dec 19th, 2007 3:15 pm
sp dash vs cr ecannon1 Supersport 9 Mar 8th, 2007 1:14 pm
