Oct 4th, 2010, 7:06 am
dyno..?
dyno of your hypermotard..?
Oct 4th, 2010, 3:40 pm
Stock or modified?  Aloha Alex
Oct 12th, 2010, 10:25 pm
dyno
80 HP rear wheel
leo vince cat Elim
tremi Slip ons
14 tooth fr
DP ECU
dyno tune tweak
K&N
DP air box mod
shanetbird
Oct 13th, 2010, 7:13 am
It might also be helpful to post the brand and type of dyno used.
'11 Hypermotard 1100 Evo
'03 DRZ400E, converted to SM
Oct 13th, 2010, 2:02 pm
Another poser topic, I'm in.
2008 Ducati Hypermotard 1100S
110,3 DIN RWHP
Modifications:
Termignoni 2 in 1 Full Exhaust System
Flowed Cylinder Heads
DP Race Cams
DP Race ECU (Reflashed for Wasp Kit)
Wasp Power Up Kit
NGK Iridium Spark Plugs
Oct 14th, 2010, 1:18 am
110,3 DIN RWHP
Modifications:
DP Race Cams
Wasp Power Up Kit
WAWAWIWA!!! is your bike a Hyper Ritmo 130 Abarth?
Oct 14th, 2010, 3:48 am
Hehehe.
No, it is just tuned.  I believe this is the max there is to get from this engine without the need for further expensive mods.
---===[ 2008 Ducati Hypermotard 1100S (110,3 DIN RWHP) ]===---
|Modifications|
Termignoni 2 in 1 Full Exhaust System, Flowed Cylinder Heads, DP Race Cams, DP Race ECU (Reflashed for Wasp Kit), Wasp Power Up Kit, NGK Iridium Spark Plugs, Ducati Biggelaar Quiet Clutch modification, Lightweight flywheel (700 gram), DP Clutchplate, Carbon Clutchcover, DP Racing Seat, DP Oil Plug, Rizoma Grips, Rizoma Brake/Clutch Reservoirs, Rizoma Rear Blinkers, Painted Racing Stripes, DP Carbon Mudguard, HK Suspension Upgrade, Bitubo Steering Damper, STM Oil Breather, GiPro Gear Indicator, DP Clutch Slave, DesmoWorld Frame and Seat Plugs
Oct 14th, 2010, 1:37 pm
Hehehe.
Hi Eric,
So did they adjust the cam timing and if so do you know what they set it at?
Oct 15th, 2010, 1:21 am
Here's mine
My stock Hyper.............. ...81.83 HP........68.03 TQ
Motor of Death I (died) ...102.03 HP........76.21 TQ
Motor of Death II ............106.57 HP........78.91 TQ
Oct 15th, 2010, 3:29 am
08Hyper can you please list your mods?
I think it will be nice to see your approach as I think our bikes are close when it comes to HP. Though the TQ differs with around 8 TQ?  (According to an online converter 110,3 DIN HP is 108.79 HP and 117 Nm is 86.28 TQ).
Are you running different sprockets than stock? I'm thinking of going with a 14t front sprocket, but not sure whether it is too much or not. Perhaps a 15/44 combination is better? Since your bike is the closest out there I hope you can tell me...
|Modifications|
