Oil leaking from clutch cover - Ducati.ms - The Ultimate Ducati Forum
Old Oct 3rd, 2010, 1:53 pm   #1 (permalink)
Rikosintie's Avatar
I rolled the HM out for a ride this morning. While doing the pre-ride check I noticed black oil leaking out of the bottom of the clutch cover. I pulled the cover and there was a small amount of oil on the bottom of the case.
This is my first Ducati and first motorcyle with a dry clutch but this doesn't seem normal.
Any thoughts?
Thanks!
Michael
Rikosintie is offline   Reply With Quote
Old Oct 3rd, 2010, 2:53 pm   #2 (permalink)
johnchypermotard's Avatar
unlikely that the oil is leaking from inside the clutch cover (it's possible, as there is an oil seal located on the case behind the clutch basket) ... it's more likely that the oil is leaking from the oil filter, and that wind is blowing the oil up from under the engine case to the bottom of the clutch cover.
Old Oct 3rd, 2010, 3:19 pm   #3 (permalink)
Rikosintie's Avatar
John;
Thanks for the quick reply. That was good tought the but area around the oil filter is spotless.I should have done some investigation before I pulled the cover and cleaned up. I will go for a ride and keep an eye on it.
Attached are a couple photos. You can see the filter is clean but there is a lot of oily dirt below the sight glass.
Oil leaking from clutch cover-hm-oilfilter.jpg   Oil leaking from clutch cover-hm-case.jpg   Oil leaking from clutch cover-hm-sightglass.jpg
Old Oct 3rd, 2010, 7:04 pm   #4 (permalink)
Originally Posted by Rikosintie View Post
John;
hmmm ... thanks for the photos. check the tightness on the side case bolts. wipe all the oil off, and then ride and check again.
Old Oct 3rd, 2010, 11:29 pm   #5 (permalink)
Rikosintie's Avatar
John;
Disregard. The root cause is too stupid to say out loud.
Michael
Old Oct 4th, 2010, 12:42 am   #6 (permalink)
Decreasing Dave's Avatar
Images: 14
Pssss......go ahead and whisper it then.
We won't tell......
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
WTB: M696 clutch cover/RHS engine case cover Speedking-MotoWerx Parts and Accessories 0 Sep 15th, 2010 3:28 pm
oil leaking from clutch? zx250r Superbikes 12 Mar 1st, 2008 9:50 am
Leaking right side engine cover? Jglisson Superbikes 8 Oct 10th, 2007 4:53 pm
Leaking 999 Head Cover?! -pic- clenart50 Superbikes 10 Sep 18th, 2007 6:21 pm
Leaking clutch ansumrob69695 Monster 5 Jul 17th, 2007 6:56 pm
