Oct 1st, 2010, 8:51 pm
Fatduc !!! well now i'm a beliver
Hi !
I order a fatduc 2 week ago,to try to cancell the low speed hick up and surge. I read some good review about the FatDuc and was pretty sckeptical.
So i just install it on the bike set it in the middle position wich is suppose to be around 13.5 AFR then start it. It run very smooth, much smoother than before.Then i done a first road test.It was way better than before, but my iddle was now pretty hight ( at around 1900 to 2000). So i try to check and reajust the bleed air screw. One was a 2 turn out the other 13/4 turn out.
At try to set them at 3/4 trn each,but it wasn't as smooth and the Rpm was a bit low at 950 to 1000. I set them to 1 turn out and now idle smoothly at 1200 to 1250. Try another road test and now supersmooth a very low rpm hight gear. Then now the surprise, turn the throttle in 2nd gear and it pups wheely as easy as it was in first before,same things in third it pups as easy as it was doing in second, and now with a small wave i can pup it up in fourth it was third before.The only other mods is a 14 TH front sprocket.
I'm very Impress. For $80.00 its by far the best mods for the buck
Motorcycle Maniac
10 Ducati Streetfighter
08 Ducati Hypermotard
08 Aprilia SXV-550
10 Gas Gas TXT280 Pro
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Oct 1st, 2010, 9:26 pm
Cant wait to see that on sunday
Oct 1st, 2010, 9:36 pm
Hey Chouch !
How are you ?
I will be there Sunday, but the Streetfighter,my girlfriend will ride my HM.
She feel better on the HM, its so much easier to ride
So i'll sacrifice myself to the cause
I will be very happy to meet you there
See you !
Motorcycle Maniac
08 Aprilia SXV-550
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Oct 2nd, 2010, 6:56 am
Originally Posted by shwantz34
Hi !
I picked one up from Nathan at the Duc Shop when I was there a month or so ago, I've got it set more towards the 14-1 end of the range and it smoothed things out and I didn't have to readjust anything, smooth idle at the same RPM as before, just much smoother at the lower revs. Definitely a cheap fix.
Steve C
www.hamptonbengals.com
2008 Hyper 1100
2008 GSXR 750 Track Bike
1972 TM 250J-"Roger DeCoster"
Oct 2nd, 2010, 11:09 am
The difference beetween our setting is probably du to the difference in Temperature.Last night it was only like 10 degree C, pretty cold so it needs a richer stting
Motorcycle Maniac
08 Aprilia SXV-550
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
