Originally Posted by slowpoke
Installation was a breeze for both parts. Instructions for the slipper was spot on.
But be warned that they don't work well with each other. EVS Slave didn't throw out far enough. Had to go back to the stock clutch slave. Now everything works fine.
The new slave should work with the slipper, just make sure its bled completely, and maybe call EVS to verify.
I have a DP slipper & aftermarket 30mm slave and all is fine. I have heard that if go to a 32mm slave you may have some issues with the clutch dragging, as the plates will not separate as far. Aloha Alex
