Sep 20th, 2010, 4:16 pm
Extended Member
Hypermotard handlebar movement
The hyper's bar is connected via rubber mounts to the triples, which I'm sure helps with vibration. Problem is that i'm starting to notice that it moves around quite a bit in aggressive riding... as I enter a turn i can almost lift it a bit, push it a bit before I get actual movement from the steering head. If you hold your bike still and lift/push on the handlebar you'll notice what I mean.
anyone else notice this? i was riding especially hard yesterday in the twisties and it got to be quite unnerving. I've noticed it before but want to do something about it now... ideas?
Sep 20th, 2010, 4:27 pm
Originally Posted by alexio
ideas?
Put some clip-ons on
Seriously you are riding the bars too hard and pretty much torturing yourself.
You have wide bars which you should be able to ride with good results without twisting things up, suggest maybe looking at your riding style when you are up it and working with the bike as opposed to against it.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Sep 20th, 2010, 4:48 pm
'09 HYM1100S Nero
Sep 20th, 2010, 7:03 pm
+1
Alex, you should be able to release the pressure from your palms and even wiggle your fingers while turning.
With the leverage these wide bars provide, the only way I could even imagine you have to push that hard on them is during a low speed full lean from one side to full lean to the other and if that's the case, you don't need our help in telling you how to ride.
I guess if the rubbers are getting worn out, that could be noticeable. I have the Scotts Damper and it came with a new triple clamp set up, problem solved.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Sep 20th, 2010, 7:12 pm
Originally Posted by Decreasing Dave
Alex, you should be able to release the pressure from your palms and even flip douchebags off while turning.
fixed
Sep 20th, 2010, 7:17 pm
Originally Posted by johnchypermotard
fixed
Welcome back John.
I was starting to worry about 'ya
My DOC Welcome Kit
Dave Yeski
Sep 20th, 2010, 7:21 pm
After several track days I have not noticed any movement in the bars. I agree with the other posters, a quick firm push to start the turn then very light if any pressure.
Sep 20th, 2010, 7:39 pm
Official Sponsor
I don't think the rizoma risers replace the rubber mounts because they are in the top triple clamp. Alot of supermoto racers replace the rubber mounts with solid mounts to make the steering more responsive. I thought about making a set for my hyper. Should we make some up? How many of you would be interested?
Sep 20th, 2010, 8:21 pm
+1
What sizes would You make?
Personally, I'm fancying a raise lyke: 45mm/1.77"
'09 HYM1100S Nero
Sep 20th, 2010, 8:29 pm
Maybe putting road rubber on the KTM EXC and flogging it might be more appropriate than twisting the Hyper's head off?
'68 BMW R69S (all original, not restored)
'01 900SS (track bike)
'10 KTM SMT
'08 Hyper S (R.I.P)
'03 HD Heritage Softail
'85 Honda Shadow VT1100C (passed down)
'82 Honda CX500 (passed down)
