Dash Turn Indicator Not Working - Ducati.ms - The Ultimate Ducati Forum
Old Sep 19th, 2010, 8:38 am   #1 (permalink)
Steve C's Avatar
Hey Guys, took the Hyper out yesterday for it's first real ride since I picked it up a month or so ago, most of the delay was due to my ripping the arse end and exhaust off to do the Yoshi pipe and Desmo Challenge tail mods.
[IMG][/IMG]
Anywho, the PO had replaced the front handguard mounted turn signals with some LED units mounted below the left and right body panels. I haven't physically looked at the wiring yet but will later today. Both the front and rear signals work fine but the dash indicator does not. I looked at the parts breakdown and it doesn't show any replacement parts other than the complete dash unit. The factory wiring diagram doesn't show any type of connection between the lights and the dash so I'm kinda scratching my head. Guess it could be a failed indicator in the dash or signal from the ECU missing, not sure.
Any thoughts are appreciated and yes I did a search and came up with zero
Steve C
www.hamptonbengals.com
2008 Hyper 1100
2008 GSXR 750 Track Bike
1972 TM 250J-"Roger DeCoster"
Steve C is offline   Reply With Quote
Old Sep 19th, 2010, 4:23 pm   #2 (permalink)
Steve C's Avatar
Found the problem, even through the signals blink OK without some load resistors on the R6 integrated tail/turn unit apparently the ECU is not happy with the "load" and won't pulse the dash indicator. I replaced one side of the R6 unit with an OEM signal and the blink rate increased and the dash indicator stated working. I then swapped in one of the resistors Chris (C2D) includes in the kit and got the same flash rate and dash indication....................problem solved, just a little soldering to do and she'll be ready to rock and roll again.
Steve C
2008 Hyper 1100
Blinker Idicator on Dash Not Working HooliganR6 HyperMotard 13 May 4th, 2010 2:42 pm
looking for a turn indicator martys Sport Classic 0 Apr 1st, 2009 11:58 am
Left Indicator and Passing Flashers Not Working (2002 M750) lightguy Monster 2 Nov 17th, 2008 4:06 pm
Small cracks near the dash indicator lights? deputydog95 Superbikes 2 Oct 14th, 2007 5:28 pm
Dash Board Turn Signal Indicator Light ST4s 2UpDuc Sport Touring 1 Apr 28th, 2006 1:48 pm
