Sep 18th, 2010, 2:43 pm
Factory Ducati dampner- Leaking!
9800 miles and my damnper has a bad leak out of the adjustment part. I just took it off the bike but seriosly hestitate to take it to Ducati! It must be a seal that is easy to replace, I hope. Anyone take one of these apart yet or have a diagram, it loks to be simple but this thing is like $800? so I'm not certain I want to Dig In w/o research first
08 HM S
05 CR500AF street project
05 CRF450X super moto/streeted
1985 Vespa ETS 125
1977 R100/7
Sep 18th, 2010, 2:53 pm
Call Dan Kyle, he can probably put you on the right track.
Sep 18th, 2010, 3:48 pm
How funny! I used to work with him in the 80's at Honda Kaw of Monterey! He's a Great mechanic!
08 HM S
1985 Vespa ETS 125
1977 R100/7
Sep 18th, 2010, 3:59 pm
if the damper is the ohlins/scotts rotary style damper, you can purchase seals for it through any ohlins dealer. very easy to take apart, replace the offending seal, and install new fluid. i have replaced seals on two ohlins/scotts rotary dampers ... and if i can do it, anyone (except francesco) can do it.
if, on the other hand, the damper is one of those POS DP rod dampers ... all bets are off on being able to get parts and service it yourself.
Sep 18th, 2010, 9:47 pm
Hey John, get it??
Now it's not a Damper, it's a Dampener........
Hahahaha.....I crack me up....
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Sep 19th, 2010, 2:58 pm
It IS one of those Dp eod dampener, no bueno, eh? Looks like it could come apart fairly easily though..
08 HM S
1985 Vespa ETS 125
1977 R100/7
Sep 19th, 2010, 4:38 pm
ciao jeff,
my comments above are based on working on the scotts/ohlins rotary style.
if you can disassemble the DP rod style (my comment about them being a POS is based on hearing/seeing lots of them leaking), you "should" be able to get seals to replace any broken/damaged ones in the unit.
once you have the unit apart, and can locate the offending seal, try sourcing a replacement seal from a good o-ring supplier.
fwiw, i have used these folks in the past:
http://www.oringswest.com/
ciao,
johnc
Sep 19th, 2010, 4:58 pm
Official Sponsor
If it is less than 2 years old warranty it with Ducati and get it replaced. They are made by FG so if you need seals/tools to do it yourself just give them a shout. I'm sure you can also send it to FG for a repair.
Sep 19th, 2010, 5:12 pm
well there ya go
Sep 19th, 2010, 5:24 pm
Official Sponsor
well there ya go
Sorry, I'm not following you - why the  ?
