need help removing side panel screws "HELP " !!! - Ducati.ms - The Ultimate Ducati Forum
Old Sep 15th, 2010, 6:11 pm   #1 (permalink)
superbike-italia's Avatar
ok i finally recieved my 08 hyper 1100s that ive been longing for, its very slightly used, the previous owner put the carbon side fairings on. im putting the originals back on and went to remove the screws on top by the gas cap and on the sides, well i think he put loctite on them so they just spin the nut thats inserted into the plastic tank, has anyone had this problem of them spinning, what to do ????IM FLUSTERED and i need some expertise help here. thanks !!!!
my current ride:
2008 ducati hypermotard 1100s black
2005 aprilia factory racing edition tuono
2007 aprilia sc 250
my past rides:
2002 ducati 998s troy bayliss edition #308/400[sold]
2004 ducati 999 fila replica[sold]
2008 aprilia sxv 5.5[550] supermoto[sold]
2007 aprilia sxv 5.5[550] supermoto[sold]
2005 mv agusta f4-1000s[sold]
2006 mv agusta 910s brutale[sold]
1995 ducati 916 sp{funeral}
FINE WINE,FINE FOOD,FINE WOMEN,FINE CARS AND FINE MOTORCYCLES!!! ITALY!!!!!
superbike-italia is offline   Reply With Quote
Old Sep 15th, 2010, 7:26 pm   #2 (permalink)
doon's Avatar
You might have to pull the insert out of the tank with the screw attached and then remove.
Epoxy the insert back in the tank.
doon is offline   Reply With Quote
Old Sep 15th, 2010, 7:40 pm   #3 (permalink)
yea i thought of that, the side one would be ok to do that to, but i have the same problem with the 2 top ones on the plate around the gas cap. not sure about working those out
my current ride:
2007 aprilia sc 250
my past rides:
Old Sep 15th, 2010, 7:51 pm   #4 (permalink)
Epoxy them in right now?
2009 Hypermotard 1100 S
2008 Aprilia SXV 550
hyper.s is offline   Reply With Quote
Old Sep 15th, 2010, 7:53 pm   #5 (permalink)
epoxy ??? what do you mean??? heres a pic of the ones that im really worried about
my current ride:
2007 aprilia sc 250
my past rides:
Old Sep 15th, 2010, 7:57 pm   #6 (permalink)
oh I see
Drill it out and replace the screw. Get a drill bit just a touch bigger than the shaft of the screw. Drill until it releases. Then deal with what you have.
Old Sep 15th, 2010, 8:04 pm   #7 (permalink)
i think thats my only option !!! ????
my current ride:
2007 aprilia sc 250
my past rides:
Old Sep 15th, 2010, 8:16 pm   #8 (permalink)
I had the same thing happen on the big on my Hyper. Drilling it out is the only way to get the panel off. Good luck getting the insert out. I start looking for a used tank.
Ted
r60slash5 is offline   Reply With Quote
Old Sep 15th, 2010, 8:21 pm   #9 (permalink)
Monstaman's Avatar
Originally Posted by hyper.s View Post
oh I see
That is what I would do too, the bolts are bloody cheesy shite so in this case that is good.
Leave as much screw sticking out so you can get some descent grip on it, a little bit of heat will also help release any loctite or in this case tank plastic... no need to give you a warning about your work surface and underneath!!
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Sep 15th, 2010, 8:25 pm   #10 (permalink)
yea i thought about heating up, the tank is empty and ill let it breath awhile so no fumes, but i think i must drill them out with a easy out and try to pull it out along with the insert, then re-epoxy the insert, uggggg it just couldnt be easy to swap out those panels
my current ride:
2007 aprilia sc 250
my past rides:
What the hell is error code "34.0 Signal Panel Sensor"? st2lemans Superbikes 2 Jul 11th, 2010 5:13 am
Vented "corse" style clutch side case cover corygt Supersport 1 Nov 11th, 2009 7:32 am
Side panel "stickers" hyperdookie HyperMotard 0 Oct 11th, 2008 6:36 pm
Removing CA "required" Fuel/Air Canister GuiTsouo Superbikes 16 May 6th, 2008 5:47 pm
