asking hyper evo or sp owners - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com Classifieds!
Old Sep 9th, 2010, 7:32 pm   #1 (permalink)
johnnie27's Avatar
Hi Johnnie here as some of you know i have a EVO sP this maybe a silly question. but when i hit the ignition on my HYPERS dash says..
hypermotard EU (what do the USA bikes say?) reason i ask is i am wanting to pull the trigger on an exhaust and was curious if i should buy from Ducati Europe or Ducati USA ...i am assuming the ECU is the same
thanks johnnie
Old Sep 9th, 2010, 8:52 pm   #2 (permalink)
Hypermotard USA
eastside is offline   Reply With Quote
Old Sep 9th, 2010, 8:56 pm   #3 (permalink)
thanks johnnie
You can change EU to other setting when engine is off. It goes from Hyper EU to Hyper En to Hyper USA to Hyper Cnd to Hyper JAP to Hyper FrA
The only difference is mesuring system (metric or imperial) and clock display.
You can buy from wherever you want, the ECU is the same worldwide. You might just have to switch back to whichever mesuring system your country is using.
Old Sep 9th, 2010, 9:09 pm   #4 (permalink)
johnnie27's Avatar
wicked thanks so much man! perfect
Old Sep 9th, 2010, 10:43 pm   #5 (permalink)
Monstaman's Avatar
Just bear in mind that if you get one from the USA you will have to stand on the other side of the bike to install it.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Sep 9th, 2010, 11:04 pm   #6 (permalink)
johnnie27's Avatar
pissssaaa and i will also be upside down
Old Sep 9th, 2010, 11:12 pm   #7 (permalink)
Monstaman's Avatar
....shouldn't need to do that ... but then you are from OZ
You may also have to get into the programming mode and change it from UCE so it will work downunder
Cheers KTiMpostor
Monstaman
TX hyper owners... jasonk HyperMotard 3 Oct 6th, 2009 9:48 pm
Hyper Owners: Need your Help. jcbertin HyperMotard 10 Aug 2nd, 2009 6:19 pm
so cal hyper owners lunch? johnchypermotard HyperMotard 22 Nov 30th, 2008 7:44 pm
hyper owners in ny dctech7 HyperMotard 15 Aug 12th, 2008 10:04 pm
