Check your chain........... - Ducati.ms - The Ultimate Ducati Forum
Old Sep 6th, 2010, 10:01 pm   #1 (permalink)
08hyper's Avatar
Exclamation Check your chain...........
F*ck me!! today while at the top of Glendora Mountain Road, the chain got thrown off! Scared me at first, I thought that I had lost the tranny. I'm not sure if I had picked up a rock that got caught in between the sprocket & chain and spit it off, or if it came off on its own. The swingarm is now gouged up, and theres a crack & chunk missing from my Shift-tec carbon hugger. F*CK!!
Either way, I found the chain was way, way too loose! I got lucky as the chain wasn't bent too badly, so I was able to reinstall it (just like when you were a kid on your bicycle) and milked her back home.
I had adjusted & lubed the chain just a couple of weeks ago, (it was pretty loose then) when I did the night track-day & only got 4 sessions in, & 1 canyon day, so really not that many miles since the chain adjustment.
I have 15,000 miles on this chain (original) and I may have pushed it too far..... so learn from me, because I am suggesting that after the 10,000 mile mark, really keep an eye on it, and after you adjust it to spec, and it gets loose really quick, replace it, its toast!
Looks like I'll have to give a call to JC Pak & order up a chain & sprocket kit. Aloha Alex
Old Sep 6th, 2010, 10:06 pm   #2 (permalink)
oalvarez's Avatar
glad you're ok my friend....thanks for the reminder.
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
oalvarez is offline   Reply With Quote
Old Sep 6th, 2010, 10:15 pm   #3 (permalink)
Wow that is really scary... glad you are ok. That could be a major catastrophy.
Old Sep 6th, 2010, 11:10 pm   #4 (permalink)
Monstaman's Avatar
Close call Alex, good you came out on the right side.
On some MH900e's and some S2R's they had some issues with the wrong size shim fitted in the eccentric thus not allowing the hub to be torqued down properly and allowing the eccentric to rotate over time, some quicker than others.
Just something to note for SSS maintenance.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Sep 7th, 2010, 1:13 am   #5 (permalink)
Official Sponsor
JCPakBikes's Avatar
Holy Crap
Did you check the engine case area?
Is that OK?
Glad you are OK Brudda
Got your call and message. I'll call you tomorrow and get you sorted out with a drive kit
Jc
jc@jcpakbikes.com
JCPAKBIKES
sportclassicspecialties.com
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
JCPakBikes is online now   Reply With Quote
Old Sep 7th, 2010, 1:49 am   #6 (permalink)
johnchypermotard's Avatar
so alex ... are you going to start a whiner thread on delicate chains now?
Old Sep 7th, 2010, 2:22 am   #7 (permalink)
disgo duc's Avatar
Images: 23
thank the lord your ok...from experience i never let my chains go more than 8 to 10k it seems after that many miles the really start stretching faster than ever!on my motorcross bikes especially my 450s i change the chains every two seasons and that taking really good care of them as well.
disgo duc is online now   Reply With Quote
Old Sep 7th, 2010, 8:10 am   #8 (permalink)
steverparker's Avatar
Your chain should last longer than 10,000 miles with proper lubing and care. What do you sprockets look like? What kind of chain was it?
steverparker is offline   Reply With Quote
Old Sep 7th, 2010, 9:11 am   #9 (permalink)
DrD
DrD's Avatar
This clip will give an sample of a day in the life of a chain and why they deserve special attention and care from us.
Dr.D
'06 Paul Smart 1078LE (too many mods to list)
'01 Aprilia SL 1000 (RSV Swingarm, RSV Shock/Dog-Bone, RSV Steering Damper, Renegage Airbox Mod, Heated Grips, Heat-Troller for Heated Gear, Tigcraft 80mm Titanium Exhaust/ECU, Custom Paint)
'89 Honda GT650 Hawk
'98 YZ400F (seized crank, still needs fixin')
DrD is offline   Reply With Quote
Old Sep 7th, 2010, 5:22 pm   #10 (permalink)
AXE
AXE's Avatar
My stock chain was spitting o-rings at 2500 miles and I ride in a pretty clean environment and am pretty good about maintenance. Others have stated the same. I suspect that there are a lot of chains like this that went unoticed.
I ran min until 5K and changed it out.
Out!
2008 Ducati Hypermotard
VIN check joshi Superbikes 1 Sep 29th, 2009 5:31 pm
Check your drive chain tension! cassos HyperMotard 1 Sep 3rd, 2007 4:52 am
VIN Check w00tw00t Ducati Motorcycle Chat 5 Aug 26th, 2007 2:39 pm
