Sep 2nd, 2010, 2:57 pm
Any difference in the termi 2-1-1 and 2-1-2
About to pull the trigger on a full exhaust. Just wondering if there's any performance difference between the two styles of Termi complete exhausts, besides the obvious look. I'm torn between the two. I like the traditional under tail look, but also love the single side look.
Sep 2nd, 2010, 4:14 pm
2 into 1 is lighter (not sure by how much) + it's a full exhaust so that = more horsepower and less restriction (someone more mechanically inclided can specify - this what I've heard).
Based on the above and look, I went with the 2 into 1. Install is expensive though...account for around an additional $300 for a Duc mechanic (if you don't do it yourself)! It does take quite a bit of time.
Current: Hyper Previous Bikes: GSXR750 and Honda 600RR
Sep 2nd, 2010, 4:44 pm
Thanks for the answer.
$300 for the install is pretty expensive. Did they have to do any tuning? I thought it was just plug and go. I think I'm leaning more towards the
2-1.
Would you know if there's a write up somewhere on the install?
Sep 2nd, 2010, 5:29 pm
my exhaust didn't come with mounting instructions and took me 8 hours to figure out and get installed! You will need to have your TPS set and your fuel trim adjusted. Before I had them adjusted, I was running very rich and was getting 60+ miles per tank.
I believe you can get a full-system now using DP collectors, Arrow headers (I believe) and the dual slipons.
I think they both look great. I imagine the dual undertail would survive better in a crash. I hate seeing my $2100 exhuast kit hanging out there in the wind.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Sep 2nd, 2010, 6:06 pm
the installation instructions that come with the DP termi 2/1 system leave a lot to be desired, as they are a b/w copy of a copy of a copy ... i have posted up a full color PDF version here:
http://www.norcaldoc.com/ldd/LDD2009/DP_termi_hyper.pdf
that make the installation a LOT easier to understand/follow.
Sep 2nd, 2010, 6:35 pm
you can get termi headers with the seimens ecu fro the 2-2 muffs
from the duc store dyno here in melb difference is around a 1 hp loss (to the 2-1) and around 1.6kgs heaverier (oh 3.5 lbs sorry) due to the extra muffler and conecting pipe..
i know in oz when fitted the bikes are all dyno'd to adjust full trim etc and re-set tps...and get a hp graph ..before and after
Sep 2nd, 2010, 11:50 pm
I went with the 2into1 and I can feel a difference in weight. Do the install your self it's not that hard and is rewarding after your done. Just get the TPS reset at the dealer you'll save a good amount. Performance is a noticeable difference and runs much smoother. I got my exhaust on ebay a lot cheaper than from a dealer look there first. John C's instructions were a big help from the one you get with the exhaust by the way.
2008 HM1100S
Sep 3rd, 2010, 8:08 pm
Thanks a million guys. I'm going with the 2-1 and will attempt the install myself. Now I just have to hit the lottery to put my order in
Sep 4th, 2010, 5:37 pm
I opted for the 2-1 and did the install myself. The install does take a bit of time even with the instructions simply because of fitting the kit (each bike is slightly different as well as each kit may not be perfect). What I did do was use the money I would have paid the dealer for the install and bought the VDSTS software from CA Cycle works. With it you can reset your TPS, adjust your fuel trim to your liking and reset the maint reminders that you would also have to pay a dealer to do as well as many other things. You may not use it everyday, but it is nice to have when you need it. Just my 0.02.
