Luca,
There is a thread on the Mid-Sized Performance Fuel Tank and there is a comparison of the four different stack kits in that thread.
However, in a nutshell, if you are looking for low to mid performance as you state, then you should be looking at the Duc Shop or TPO Beast (not the R). The Duc Shop ones cost less and are nicely made.
As far as the ECU, you will probably need at least the Cams ECU with your set-up and your altitude. I'm leaning toward the same direction in mods as you and I have the same ECU that you currently have. However, I'm at 4600 MSL and I may be ok, maybe not.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
