Originally Posted by Harmon
There is no setting for that on the 2010 model. Because of the new ECU. At least that is what the dealer said.
ah...haven't played with a 2010.
Originally Posted by disgo duc
how do you get to the lamp/led mode ? is there another thread on it?
Service Menu
The instrument panel features a service menu that should be used only by the dealer, in case of real need.
To enter this service menu, hold button (MODE) pressed in position A "s" and at the same time turn the key from Off to On.
Pressing button (MODE) in position A “s“ or B “t“ the available functions are displayed one after the other.
After enabling functions and/or changing settings, turn the key from ON to OFF to store any changes.
Upon the following Key-On, the new settings will apply.
This menu features three functions:
Immobilizer Reprogramming (PRO 0000);
Unit of measurement setting for displayed values (SET UNIT);
"Manual" movement of the exhaust butterfly valve (SET EXVL);
Rear indicators setting (SET INDIC).
SET INDIC
Service MENU - Rear Turn Indicators Setup
This Function allows you to set the correct piloting of the rear turn indicators.
The vehicle comes as standard with bulb rear turn indicators (10W); if the owner wishes to change them and fit Led Ducati Performance indicators, after installation it is also necessary to set them within this page of the Service MENU.
To view this function, access the "SERVICE MENU" and enter the "Set INDIC" page.
Then press button B for 3 sec. to enter the "SEt" mode.
The display reads "LAMP" (bulb type); press button A (s) to switch to "LED" (Led type).
Once the correct type of turn indicator is set, press button B and hold for 3 sec. until "MEM" (memorised) is displayed.
Take the key to "OFF" to save and quit this function. Upon the following Key-On, the Dashboard goes back to normal operation.
