Advise needed - Ducati.ms - The Ultimate Ducati Forum
Patriot Powersports
Old Aug 19th, 2010, 9:36 am   #1 (permalink)
Location: Northern, , Ireland (Ducati Hypermotard 2012 evo corse 1100)
Advise needed
I went out to start my Hyper yesterday and when i pressed the started there was just a clicking nose. I tired it serveral times and then she did start. It then happened again later on and I did notice that the top right hand orange light was on, Is this a serious problem or is it a loose connection or has any of you guys had the same prolem?
"ye must be born again" John 3 v 7
Darsey is offline   Reply With Quote
Old Aug 19th, 2010, 9:49 am   #2 (permalink)
Sounds like it might be a loose battery terminal, (or dead battery.) Usually the clicking is the starter solenoid pulling in but there is not enough current flowing to turn the motor over.
I hope that's all it is.
1931scott is offline   Reply With Quote
Old Aug 19th, 2010, 10:24 am   #3 (permalink)
yeah, the clicking sound usually points to a battery issue.
dod you checked the voltage indicator on dash? if its lov, the numbers should blink (i think under 11.5V but not sure)
joenavran is offline   Reply With Quote
Old Aug 19th, 2010, 11:18 am   #4 (permalink)
did you happen to put the key in "P" instead of "LOCK"?
i did this once on one of my other moto's.
put the battery on a charger, and you should be good to go.
Old Aug 20th, 2010, 10:12 am   #5 (permalink)
thanks guys just going out now to check terminals etc
Advise please Raiden HyperMotard 17 May 20th, 2010 6:57 pm
advise needed fever Superbikes 4 Dec 31st, 2009 12:40 pm
Dayton Freight Wrecks my 748...admits it and won't pay...advise needed. Mirek Superbikes 16 Jul 1st, 2007 10:10 pm
New Guy Need Some Advise RYMAN Monster 3 Sep 27th, 2006 7:12 am
