Flashing Fuel Indicator - Ducati.ms - The Ultimate Ducati Forum
Patriot Powersports
Old Aug 17th, 2010, 4:32 pm   #1 (permalink)
NYSport's Avatar
Images: 4
I just went for a blast to look at my "potential" new bike and on the way back the fuel light started to flash. I was low on fuel but the low fuel light is steady and triggers the mileage clock to start. I lost my horn and turn indicators at the same time. Probably a fuse but I'm interested to know if anyone has run into to this problem. Tom
BTW, the bike runs great!
Old Aug 17th, 2010, 5:27 pm   #2 (permalink)
doon's Avatar
Its telling you to hurry up and install the midsize(performace tank)
Must be an electrical short some where
doon is offline   Reply With Quote
Old Aug 18th, 2010, 12:13 pm   #3 (permalink)
NYSport's Avatar
Images: 4
Nobody knows what a flashing fuel light means?
Old Aug 18th, 2010, 12:49 pm   #4 (permalink)
was it steady at first, then start to flash?
Old Aug 18th, 2010, 1:35 pm   #5 (permalink)
NYSport's Avatar
Images: 4
Nope, started flashing. But I did remedy the situation, maybe not fixed but everything is back in working order. It was a fuse! How I missed it is beyond me. Now what caused the fuse to blow is still unclear. I did go through the wiring and the pod on the left side handle bar (source for most of the bad indications, horn, high-beam flash and turn signals) to check for wear or abrasion on any wire. Everything looks fine, time will tell.
The flashing fuel indicated might be an alert for a blown fuse but nobody can confirm that, and how it's otherwise connected to the lights/horn are unclear.
Old Aug 18th, 2010, 3:28 pm   #6 (permalink)
joshuaz2's Avatar
i posted this a while back when mine did the same thing. it is a fault indication that the fuel sender is bad or the wiring has an open. mine is the fuel sensor open. good luck i have been waiting for months and have run out of gas twice.
09 Honda CRF230L
joshuaz2 is offline   Reply With Quote
Old Aug 18th, 2010, 10:54 pm   #7 (permalink)
Fuses only blow for one reason. An over load on the circuit. There's a SLIGHT chance the was a fluke, but I would never believe it personally. Don't think it would be very hard to open up most of the circuits and check continuity between the open circuit and ground (frame)
Current rides:
2010 HYM EVO SP
2008 Yamaha R1
2011 KTM 250SX
2010 KTM 300XCW
2003 Honda CR250 (Old trusty)
2009 Skidoo Summit 146
UTrider is offline   Reply With Quote
Old Aug 19th, 2010, 10:09 am   #8 (permalink)
But I did remedy the situation, maybe not fixed but everything is back in working order. .
Can I assume this means we are on track to be on track at Monticello?
Fess is offline   Reply With Quote
Old Aug 19th, 2010, 10:26 am   #9 (permalink)
NYSport's Avatar
Images: 4
I'm doing some QA as per UTrider's remark. I did some wire relocation and so far so good but no specific "ah ha" findings. Monticello is on!
Old Aug 19th, 2010, 11:40 am   #10 (permalink)
Good. Now sign up for American Supercamp in Nov!
'05 999 EOBD light and Flashing "CODE" indicator dammage Superbikes 12 Jul 20th, 2010 1:01 pm
Strange Fuel Indicator Phenomenon stotan71 Sport Touring 4 Oct 9th, 2008 8:42 am
Re-flashing the ECU? High_side Sport Classic 5 Jun 14th, 2008 2:18 pm
Fuel level indicator for 996S ducatidude996s Superbikes 4 May 22nd, 2007 7:53 pm
flashing wrench xerox18 Superbikes 2 Mar 16th, 2007 9:59 pm
