i got mine last week. i was torn between the 2-1 or the slip-on and arrow collectors. i ended up getting the slip-on and will order the collectors soon.
install took about 15minutes, but i already had my old exhaust off because i had my sub-frame powder coated while waiting for the exhaust.
well here's some cell phone pics from when i installed it.
i'll put better pics once i get the collectors.
the can is not dented, it's just the lighting. Included in the kit is an adapter pipe which move's the pipe back i think 60mm. i preferred the shorter look.
nice and tucked close to the sub-frame. for the license plate mount, i used parts off my EvoTech Tidy Tail, bolts from the stock tail and bolted it to the sub-frame where the flapper solenoid was.
i also installed my LED turn signals up made by HyperLite.
http://www.hyperlites.com/ i used small pieces of sheet metal to angle the LED's so that they are facing forward. they are attached to the wings using 3M trim tape.
