Broken tank side covers..... - Ducati.ms - The Ultimate Ducati Forum
Patriot Powersports
Old Aug 15th, 2010, 7:29 pm   #1 (permalink)
08hyper's Avatar
Angry Broken tank side covers.....
I just noticed that my tank covers bottom mount hole is broke off, (Left side) & cracked on the right side! this sucks, as these cover are expensive....
I tried to apply some JB weld to the broken piece, but it still came off.
Has anyone fixed this yet? if so how did you do it? thanks, Aloha Alex
Old Aug 15th, 2010, 7:38 pm   #2 (permalink)
dreyes's Avatar
Had the same one crack after a minor low-side. Epoxied mine & used a clamp until it was dry. As soon as I released the clamp it separated again.
Hope someone does have a good idea. Not that it's affecting anything, just annoyed knowing it's broke...
dreyes is offline   Reply With Quote
Old Aug 15th, 2010, 7:53 pm   #3 (permalink)
A super glue gel may work.
Ted
r60slash5 is offline   Reply With Quote
Old Aug 15th, 2010, 8:21 pm   #4 (permalink)
johnchypermotard's Avatar
alex,
i refer you to your own words of wisdom ...
http://www.facebook.com/video/video.php?v=1149672347907
Old Aug 16th, 2010, 12:18 am   #5 (permalink)
disgo duc's Avatar
Images: 23
hey alex try calln a automobile paint store and ask for a 2-part panel to body agent or epoxy..forget the name of it...maybe everbond its used for putn plastic panels to steel body and it works very well almost to well!they will know what your talking about.that will definitely work for ya but its not cheap and it uses a special gun..but they may have something in smaller portions.if i lived near ya i would let you use mine...
disgo duc is online now   Reply With Quote
Old Aug 16th, 2010, 2:47 am   #6 (permalink)
Decreasing Dave's Avatar
Images: 14
It's only a 5 hour drive.
What kind of lousy friend are you??
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Aug 16th, 2010, 3:09 am   #7 (permalink)
Pop
Pop's Avatar
Yep, fixed.
The problem is the mounting hole is 2-3mm too far back from the plastic panels locating point. Drill out the hole and then buy a rubber grommet and mount it into that
Pop is offline   Reply With Quote
Old Aug 16th, 2010, 8:37 am   #8 (permalink)
Vdue's Avatar
Had this issue now twice. First time it was replaced under warranty. Second time I fixed it. The problem are the few tools sitting in the cover.
I bent from 1mm aluminum some sort of bracket and glued it with 2-compo epoxy into the cover. Now it works for almost 5K. The epoxy glue is available in your DIY shop. There are different kinds, slow, normal and fast. I took that one which you can correct within the first 10min. I would not recommend one of these 1,2,3 sec glues.
http://www.moto.dotklein.com
1198 SP '11
HYM S '08
Roughneck '07
Vdue is offline   Reply With Quote
Old Aug 16th, 2010, 9:04 am   #9 (permalink)
08hyper's Avatar
Originally Posted by Pop View Post
Yep, fixed.
I can't drill it out, the bottom of the mounting hole is now gone, I want to try and "epoxy/glue" A metal washer in its place, I just meed to find a product that will bond to the side cover material. (any help?) Aloha Alex
Johnc, I should have known you would bring back the "redneck" someday...
Old Aug 18th, 2010, 11:01 pm   #10 (permalink)
I read this the other night and it made me look at mine.. If my lower post was broken, I may have a simple fix.. Make a small L bracket that attaches to the metal post and use double sided 3M tape to attach bracket to inside of the tank. If the tape ever failed, replacing it would take minutes.. The stock plastic bracket is kinda a joke
Current rides:
2010 HYM EVO SP
2008 Yamaha R1
2011 KTM 250SX
2010 KTM 300XCW
2003 Honda CR250 (Old trusty)
2009 Skidoo Summit 146
UTrider is offline   Reply With Quote
Those little side-covers on the GT... TiltTheHorizon Sport Classic 11 Jan 25th, 2010 2:25 pm
Looking for GT Side Covers GTRossi Sport Classic 0 Nov 2nd, 2008 8:05 pm
GT Side Covers bavarian3 Sport Classic 14 Oct 13th, 2007 2:06 pm
695 side covers highlander Monster 1 Jun 30th, 2007 11:16 pm
