Aug 11th, 2010, 1:30 am
Hyper torque...???
Hi all,
I am just a bit confused with the Hyper torque... I hear everyone is doing wheelies in second and third gears and I can do it only in first gear. Not much power do it at 2 or 3...
I am quit confused now whether it is me (I weight 100kg), or there is smthg wrong with my bike...
I got a dp ecu, zard headers, termignoni manifolds and dp airbox lid.
My dealer set a fuel trim at +10 I think, because the bike was quit lean when I turned up at the dealer shop.
When you pull the gas the rpms climb quit fast... but it seems like instead of getting much faster bike only gets a bit faster and much more louder... basically at around 5k rpm the sound is like the engine is going to explode...
I think there is more of that power in my bike that isnt unleashed.
What do you think guys what can it be? Or maybe I just got used to the torque and now want even more...??? But...the wheelies... even if I pull up the bike there is no way to do it in second gear...
Aug 11th, 2010, 3:03 am
I'd say it's just you at this stage.
Mine does power wheelies in 3rd gear no probs and standups in fourth no clutch.
Engine stock, down one tooth on the front.
Aug 11th, 2010, 3:45 am
Location: Northern, , Ireland (Ducati Hypermotard 2012 evo corse 1100)
its certainly to do with the man on the bike. i can remember doing wheelies on my pushbike and do wheelie on the hyper is really easy keep practising.
"ye must be born again" John 3 v 7
Aug 11th, 2010, 4:04 am
Originally Posted by sst256
Hi all,
Crack the throttle open at 2.5 k in second gear and be ready
The higher the rpms the less chance it will lift, thats what I have found anyway
Aug 11th, 2010, 6:20 am
I ve done it many times but at 2,5k it seems like the engine is struggling to gain power... feels like there is a trailer tied up to the hyper. 3,5-4k is the range where my engine becomes alive and accelerates much better... but still not enough for a wheelie.
Aug 11th, 2010, 7:22 am
I have no issues lifting the front wheel in second or third, but how do you keep the wheel in the air for a longer period in time? Full throttle or would that flip the bike over?
I find it hard to explain what it feels like to do wheelies on the Hyper. I mean it's real fun to do and I would like to do longer ones but I'm also scared in some way to pull to far and drop the bike.
Any advice... besides practice, practice, practice and keeping your right foot near the brake?
Aug 11th, 2010, 7:42 am
Something strange going on. Mine is stock other than the Termi 2-1 with DP ECU and I just roll the throttle on from 30mph in second and the front comes straight up.
2008 Ducati Hypermotard, 1970 Suzuki TC 120 sold
2005 KTM Supermoto sold, 1972 Suzuki TS250 sold
2002 KTM Supermoto sold, 1972 BSA 500 sold
1968 Ducati 350MKIII Desmo, 1978 Suzuki GS550 sold
1979 Honda XL500 stolen
Aug 11th, 2010, 10:38 am
In first gear I just open the throttle half way and then when the wheel comes up just keep slightly flicking it (open - close - open - close) to maintain balance and it goes fine... can wheelie untill full rpm reached but in second even if I open the throttle full way down the wheel doesn't even come up (((
Aug 11th, 2010, 10:50 am
If you have access to a dyno, you can see what the HP/TQ numbers are relative to others with these mods, that will help verify if the problem is in the bike or setup. Why it sounds like it is going to explode is beyond me.
First and second should be no problem. You definitely are going to have to be in the sweet spot for thrid, which for me is around 3500 rpm and give a little tug and lean back. You should be able to run them forever in third just by feathering the throttle. This bike flies straight as an arrow on the rear wheel.
Alot of weather variables can your performance. If it is unusually hot, humid, or if you are in a higher elevation say above 2500 msl you may not be able to get third, but second should still not be a problem.
Out!
Aug 11th, 2010, 10:59 am
+10 fuel trim sounds a bit low for headers and air box mods. Mine was lean with +8 (slip on ecu) with the LV cat pipe and Zard slip ons. Bumping it to +15-18 made a big diffeence in throttle response and power.
