throttle slop - Ducati.ms - The Ultimate Ducati Forum
Old Aug 4th, 2010, 8:31 pm   #1 (permalink)
throttle slop
Whats the best way to adjust the throttle cable on the 796?
cpike is offline   Reply With Quote
Old Aug 4th, 2010, 9:44 pm   #2 (permalink)
AXE
AXE's Avatar
G2 Ergonomics throttle.
Out!
2008 Ducati Hypermotard
Old Aug 4th, 2010, 10:09 pm   #3 (permalink)
The stock cable should have and adjustment as most other bikes have, so you can get it right. Follow the cables down from the throttle tube and you should find a section that's a little thicker then the rest, under the rubber boot is the adjuster.
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
Steering head bearings slop. Bly Sport Classic 15 Aug 8th, 2009 1:54 am
No Slop Throttle Tube dukepilot HyperMotard 51 Feb 17th, 2009 2:06 pm
Throttle Slop AXE HyperMotard 4 Oct 5th, 2008 12:02 am
driveline slop.... s14unimog Supersport 2 Apr 9th, 2008 1:46 pm
Adjusting out throttle slop, a few questions. Kylipso Superbikes 5 Mar 2nd, 2008 8:48 pm
