Originally Posted by Mr Mike
I think you answered your own question very well.
Others with fat duck have had similar issues.You could back of a tad on your setting if it bothers you.
I had an FJR that would flash a code if I ran at low RPM steady speed for more than 15 minutes.
Cleared up once I ran it out.
Doesnt sound like a problem.
Thanks Mr Mike. I figured as much, just was wondering if anyone has seen it as well. Possibly, and more likely, it was more of a value code since the ECU probably saw values past what is normally acceptable. This was probably faciliated by the FatDuc's offsetting.
Dan
