Does your hyper cry? - Ducati.ms - The Ultimate Ducati Forum
Old Jul 18th, 2010, 10:09 am   #1 (permalink)
yabo0569's Avatar
I made a little road trip with some friends just outside of philly to see Jason Britton. I think I might be on the speed channel. I got recorded pulling away on the hyper. Ok, now back to my question, I got there and I noticed a little bit of oil coming out of the engine case. That is the first time I noticed that on my bike. I had the hyper now for 2 years with 10K miles on it. I torqued the bolts a little more and wiped the oil off. We drove back from philly and there was more oil coming out. Do you guys know the cause? bad gasket maybe?
yabo0569 is offline   Reply With Quote
Old Jul 18th, 2010, 10:32 am   #2 (permalink)
The the rpm/timing sensor that is on top of the case leaks a little on mine and my left side case looks about the same after a ride. It just has a o-ring on it, and tends to weep. Be careful just tightening bolts...not everything has oil on the other side. If you do want to tighten things as you should use a torque wrench and proper torque spec. when oil is spotted follow the trail UP to the culprit. Also, no real "gaskets" on the DS1100, just o-rings and sealant.
*if you know this then good, not all people do...just don't want you to open a can of worms stripping a bolt into the case. then asking how to use a helicoil.
2009 Ducati Hypermotard 1100 w/ DP Termi 2-1 Kit
singlefin is offline   Reply With Quote
Old Jul 18th, 2010, 11:10 am   #3 (permalink)
Quick as a lickety split
hooptygoo's Avatar
Mine does. A little at the front cylinder cam and valve covers and a little less from the left side case cover. It's not much more than a film to be wiped off after a ride. My question would be how much do you chalk it up to owning a Ducati and how much does it take to warrant warranty work?
Jon
05 Sportster 1200 - Sold
82 GPz 750 - Sold
71 CL 175 Scrambler - Sold
09 Hyper 1100S "BIGTARD" - Sold
02 Monster 620 "Piccolo Mostro"
hooptygoo is offline   Reply With Quote
Old Jul 18th, 2010, 2:30 pm   #4 (permalink)
NikMusolino's Avatar
My 09 S had a leak on the underside of the clutch-side casing, it wasn't a matter of the bolts being down to spec, but the seal was bad. It was fixed under warranty.
'09 HYM1100S Nero
Old Jul 18th, 2010, 2:47 pm   #5 (permalink)
freezer16801's Avatar
mone started leaking in the area that yours is leaking after I removed the charcoal canister. The mounting bolts of the canister weren't tight. I don't know if you tried those on yours?
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Jul 18th, 2010, 11:49 pm   #6 (permalink)
yabo0569's Avatar
thank you guys for the input, really helpful. I'm taking it to the dealer. I'm lucky my warranty expires at the end of this month.
Hyper 796 or refinish the garage? -> the Hyper won! spindrift Welcome and Introduction 5 Jul 14th, 2010 1:17 am
Considering a Hyper like2ride HyperMotard 11 Dec 17th, 2009 9:55 am
buy used 08 hyper or wait for new 796 hyper? nikkihyperr HyperMotard 12 Oct 10th, 2009 12:00 pm
Hyper vs Fit guzzi3 HyperMotard 0 Apr 29th, 2009 6:34 am
Is the Hyper right for me? NorCalDuc HyperMotard 8 Apr 24th, 2008 9:27 pm
