Hyper796 Noisey Forks - Ducati.ms - The Ultimate Ducati Forum
Old Jul 14th, 2010, 4:21 pm   #1 (permalink)
stuntrider7x's Avatar
Hi, when I push the forks down on my hyper796 I hear a noise that sounds exactly like the springs rubbing something, I have never heard forks make noise like this out of all the bikes I have owned and its deffinitly comeing from inside the tubes when I push them down (I do not hear it on rebound only when pushed down) but the forks do work fine just dont like this noise at all, Anybody with a 796 please push your forks up and down and tell me if yours makes noise Thankyou! ((Also I Do Not Hold Brake Lever When I Push The Forks Up And Down To Avoid Brake Rotor Clicking))
stuntrider7x is offline   Reply With Quote
Old Jul 14th, 2010, 7:54 pm   #2 (permalink)
freezer16801's Avatar
I am wondering if you installed frame sliders? The reason I ask is I had a noise similar to what you are describing in my 1100. With the help of other members here, we were able to determine that the engine mouting rod that is replaced as a part of the frame slider install was corroded/rusted and causing a creaking sound that I could've sworm was coming from the forks. At least it only happened when I compressed the forks.
You just need to force the rod out with the stocker and grease the heck out of the aftermarket one, once you clean off the rust.
Let us know if this is relevent.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Jul 15th, 2010, 12:01 am   #3 (permalink)
Nginear's Avatar
I haven't noticed any sound like that my 796.
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
Nginear is offline   Reply With Quote
Old Jul 15th, 2010, 8:06 am   #4 (permalink)
Nah its deffinitly inside the tubes, If I put my ear against them and have someone push them down I can hear the springs making noise and noise is the same on both tubes, I stoped by my dealer with bike and they said its the oil flowing through valves.
Old Jul 15th, 2010, 9:15 am   #5 (permalink)
Decreasing Dave's Avatar
Images: 14
Haha...well then the 796 forks must be better than the 1100 forks because on the 1100s, no oil flows through the valves....
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jul 15th, 2010, 4:56 pm   #6 (permalink)
so you havn't put on frame sliders? Because I was equally convinced that it was my forks as you are. I know my way around a bike as well. Just something to eliminate, I suppose.
08 Ducati HM
Old Jul 15th, 2010, 5:40 pm   #7 (permalink)
Nope no sliders, It is deffinitly spring noise cause its coming from the top of the tubes and sound is the same in both tubes, sounds like the springs are rubbing the tube walls. The 796 fork internals and springs are a bit different looking on the microfiche but I have never heard the springs inside any forktube befor on any of my other bikes.
Old Jul 15th, 2010, 9:53 pm   #8 (permalink)
Just picked up a 796. Forks sound exactly as you describe. I asked the mechanic about it and he said it's normal, even though I've never heard that before either.
So here is my sound question. When I decelerate with engine braking, I hear what I would call a metallic burping. Could be the exhaust, but I'm also wondering if it is the slipper clutch. I've only been on one 70 mile ride and I was wearing ear plugs. Any ideas?
RichardU is offline   Reply With Quote
Old Jul 16th, 2010, 7:23 am   #9 (permalink)
These engines make a ton of different noises but I would say its that huge cat on the bottom and especially with quiet exhaust you always hear everything I have noticed, Im gonna be riding all day today and gonna have a close listen. As for the forks yea its really weird but im glad someone else has noticed the same thing. Thanks everbody for all your imput!
Old Jul 17th, 2010, 10:20 am   #10 (permalink)
Went out for ride yesterday and within a few minuits i picked up a huge vibration noise coming from inside the cat, Man what a peice of junk something broke inside the cat and is making such a loud vibration noise other riders say they can hear it when behind me, I need to get rid of the cat somehow Im verry unhappy!
WTB Matris F05R forks internal Cartridge for s2r1k Showa forks. erichan8757 Parts and Accessories 1 Jun 21st, 2010 3:59 pm
2009 forks vs. 2008 forks??? bigmacduc HyperMotard 15 Jan 30th, 2010 5:00 pm
Stock 1098 forks vs stock 749S forks RatFink749 Superbikes 1 Jan 20th, 2010 11:36 pm
New Ohlins FG R&T forks 2008 fit on 999? or 1098 forks on 999? makorn Superbikes 22 Jul 16th, 2009 6:24 pm
Is there a difference between oem ohlins forks and ohlins R&T forks? S4one Superbikes 1 Jul 30th, 2007 7:59 am
