The stock brake light switch will work with the RCS. You will need to make or buy a new reservoir mounting bracket. Simple enough to make with a piece of aluminum.
If you plan on going with the single front brake setup, the RCS is going to be too big. You'll need around a 14mm master cylinder. Magura makes a nice one or you can adapt a Nissin m/c from a TRX quad.
Originally Posted by Blorton
Will the stock reservoir, wiring and brackets from my S plug straight in, or do I need to replace those as well?
Thanks.
