Stutter at low rpm - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com
Old Jul 12th, 2010, 7:34 am   #1 (permalink)
Stutter at low rpm
This is my first duc, so i don't know if this is normal.
Anything below 3000rpm I feel like the bike is clunking kinda as if while riding an inline four and trying to takeoff from a dead stop in 3rd gear ....
I don't know if i am explaining myself right.
I'm wondering if it has something to do with the stock gearing .
Any input could help
2low4nyc is offline   Reply With Quote
Old Jul 12th, 2010, 8:11 am   #2 (permalink)
These engines don't like low RPMs. Below 4000 it will lug when you try to get on it. Adjusting the air bleed screws and taking all the slack out of the throttle cables helps but you need to ride it like you stole it. I ride between 4000 and 7000 RPMs all the time, that is the happy spot for the Hyper. It will never act like an inline 4 so don't try.
Enjoy the song of a Duc wailing down the road.
Take no guff from these swine,- Dr. H. Thompson
Dr. John is online now   Reply With Quote
Old Jul 12th, 2010, 9:36 am   #3 (permalink)
bromike666's Avatar
Get a Fatduc and Iridium plugs, it'll smooth out a lot of the lug at low RPM's.
"I love the sound of a dry clutch in the morning"
10 F1098S Streetfighter
08 Hypermotard 1100S
08 Multistrada 1100S
07 SM610
bromike666 is offline   Reply With Quote
Old Jul 12th, 2010, 12:40 pm   #4 (permalink)
I've heard of fatduc but watt is it?
Old Jul 12th, 2010, 1:54 pm   #5 (permalink)
Linear O2 Manipulator. With stock ECU, below ~4k RPM the engine is closed loop (i.e. using oxygen sensor to obtain a certain AFR). The fatduc goes inline with the O2 sensor to trick the ecu into thinking it is running leaner to richin' it up. Purely a voltage change i believe.
Dan
Fast_Momo is offline   Reply With Quote
696 Front Brake Stutter Trabftw Monster 10 Apr 5th, 2009 4:34 am
