Can I change my 796 rear shock?
Hi guys
Got a Hyper 796 but the roads here in Singapore are sure bumpy. Planning to change my rear shock to Ohlins Adjustable Rear Shock (DU36520811A) that fits a 1100s and 1100 EvoSp
The problem is two sources (via online stores) stated that the Ohlins can't fit the 796 while one source said it will fit since the 796 swing arm, frame & rock arm has the same part number as the 1100.
So does it fit a 796?
