fuel pump - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Graves MotorsportsMotorcycle.com
Old Jul 8th, 2010, 2:06 pm   #1 (permalink)
fuel pump
one simple question
is there any way that a fuel pump has something wrong with it , IF:
when the bike is running - it runs fine
only issue is "PUMP ERROR" appears on dash and fuse keeps blowing .
in other words
can a pump simply draw too much current , enough to blow a fuse but only sometimes?
2low4nyc is offline   Reply With Quote
Old Jul 8th, 2010, 3:50 pm   #2 (permalink)
Decreasing Dave's Avatar
Images: 14
In general, yes.
Several things can cause something like that to include bearing failure and/or balance issues. The added resistance in the spinning of the rotor would cause a higher than normal amperage draw, possibly blowing the fuse.
I don't know if our bikes have a constant current to the fuel pump (I wouldn't think so), but if they did, it would explain you disconnecting/reconnecting and being able to run without blowing a fuse. otherwise, I'm not sure why that action would make a difference with a faulty pump.
I hope I helped.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jul 8th, 2010, 8:23 pm   #3 (permalink)
Originally Posted by Decreasing Dave View Post
In general, yes.
I hope I helped.
Dave
im only asking this again cuz i really hope my bike doesnt have an electrical issue . i rather it b the pump so the issue is resolved once and i wont have further issues . ducati service has had my bike 3 days and still havent looked at it . im nervous its gonna cost me alot of money .
Old Jul 9th, 2010, 1:26 pm   #4 (permalink)
GMP
If it is bad they will likely try and hit you for a complete flange assy for around $900 as that is the way Ducati sells it, which is fucking crazy. Be smart, say no thanks, and buy the pump alone from CA cycleworks or Desmotimes for $150 and do it yourself.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Jul 9th, 2010, 2:04 pm   #5 (permalink)
Images: 14
Oooooo, good info.
Thanks,
Dave
My DOC Welcome Kit
Dave Yeski
Old Jul 9th, 2010, 6:10 pm   #6 (permalink)
Oooooo, good info.
Thanks,
Dave
You guys will never guess what was causing the issue.... I have a ca cycle works tank and when i put it on and put the tank bracket on , it was on so tight that it was cutting into the wire of the fuel pump so they repaiared it but i need to modify the bracket or put spacers on it so it hold the tank down but doesn't touch the wires.....so stupid ....
Old Jul 9th, 2010, 7:09 pm   #7 (permalink)
AXE
AXE's Avatar
The first step to recovery is admitting guilt. The second is admitting that it sometimes pays to read the directions.
Out!
2008 Ducati Hypermotard
Old Jul 9th, 2010, 7:34 pm   #8 (permalink)
Out!
it was def my fault . but i feel that CA cycleworks could have provided a bracket that fit better than stock
Old Jul 9th, 2010, 8:31 pm   #9 (permalink)
Images: 14
Oh, nice!!
Come'on now. You installed the tank, don't blame the manufacturer.
If Ducati had made the bracket bigger, (anticipating that you would install a larger tank, then not check your work to make sure that you didn't pinch any wires), then you wouldn't have had that problem.......
Glad it turned out ok.
Dave
My DOC Welcome Kit
Dave Yeski
Old Jul 9th, 2010, 9:24 pm   #10 (permalink)
Talking
Oh, nice!!
Dave
but theres really no way around no pinching wires in this setup - i think the canal for the wiring in the tank should be deeper or they should have provided a better bracket ......other than that its my fault
After-Market Fuel Cap and Fuel Pump Hoses joeychitwood Sport Touring 2 Jun 15th, 2009 11:01 am
996 Fuel pump seal and female fuel connector thedjmongoose Superbikes 2 Apr 29th, 2009 2:51 pm
Any way to test fuel pump... without fuel? TrojanHorse Superbikes 1 Mar 9th, 2009 3:01 pm
O Ring on fuel pump = fuel weeping ST4 Steve1445 Sport Touring 4 Jan 28th, 2008 5:09 pm
The Dreaded Fuel Line/Fuel Pump Separation Revisited BlackDuck Sport Classic 3 Sep 21st, 2007 5:51 am
