Originally Posted by kingsnake1650
I just installed the boomtubes on my hyper and I dont have the DP ecu yet (will be here later this week) so since I have removed the flapper servo and the O2 sensor I have a check enging light. I want planning on riding until I got the new ecu in but now I board and need to get out of the house?
I have a PC3 and a fatduc on the bike so Im not worried about running lean or anything but I didnt know if the cpu affected timing curve or anything like that.
any thoughts?
How could you connect a FatDuc with no oxygen sensor?
This bike should not run well with a standard ECU and no oxygen sensor-- the
O2 reading will always be railed to one side. This apples to part throttle
operation or running at RPMs less than about 4500, in which case the stock
ECU is in closed-loop mode and relies on the feedback from the oxygen
sensor to self-adjust the air/fuel ratio. With no Lambda sensor, the ECU
will detect NO oxygen and have no feedback on adjusting fuel injection
pulse duration for the target A/FR. I'm betting it will run like a dog, although
the Check Engine errors may initiate a fail-safe mode and arbitrarily set
fueling to some (half-way) usable midpoint, but I don't know if this ECU has
the "limp-home" capability or not.
Keep in mind that the FatDuc device connects between the Oxygen Sensor and the ECU...
it does not _replace_ the O2 sensor, it merely manipulates the voltage out of it.
