Pump Error ( fuse) - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Jul 4th, 2010, 9:46 am   #1 (permalink)
Pump Error ( fuse)
anyone know why my fuel pump fuse keeps on blowing ? i checked the wiring to the fuel pump and looks good .
the other day i was on the highway and all of a sudden my bike had no power and check engine light came on , i pulled over and looked at the dash and it said pump error so i check the fuse and thats what the problem was . i changed the fuse and i was on my way , a few mins later it happened again. changed the fuse and the bike worked , then it happened again but this time when i changed the fuse , it would blow as soon as i turned the power on . i went thru 6 fuses and still didnt work . finally i unplugged the wire going from the fuel pump to the wire harness and plugged it back it , changed the blown fuse and it worked , i was able to get home . now i dont trust my bike until ducati looks at it.
this happened once before so since then i carry fuses.
i feel it could either be the wire coming from the fuel pump or the fuel pump itself . i dont know what else could be causing this .
any suggestions? it going to ducati on tues for this and for 7500mi service . i just wanna be somewhat prepared so that when i talk to the tech i can give him a better idea as to what to look for .
thanks
2low4nyc is offline   Reply With Quote
Old Jul 4th, 2010, 10:06 am   #2 (permalink)
MTScott2's Avatar
Images: 5
Tell me how bad of an idea this is , carry a slightly larger rated fuse say a 12 where it calls for a 10, If it keeps blowing well try the bigger one only as a tempoary fix , just to get you home ....
Tempoary unless it works that is...
2011 Red Multistrada Touring
Old Jul 4th, 2010, 10:09 am   #3 (permalink)
Decreasing Dave's Avatar
Images: 14
Bad idea.
What he has been doing has been working for getting him home. Fuses are sized the way they are for a reason.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jul 4th, 2010, 10:15 am   #4 (permalink)
Originally Posted by Decreasing Dave View Post
Bad idea.
Dave
i agree but i did think about that . what else could this possibly be ?
Old Jul 4th, 2010, 10:20 am   #5 (permalink)
Images: 14
I'm leaning towards the pump or the connection to the pump.
If you disconnected the pump, then just reconnected it and all was well again, basically, you (apparently unknowingly) isolated the problem from the connection to the pump.
Now, it could be either end of the connector, the wiring to the pump or the pump itself.
Armed with this info, the Tech should have an easy time diagnosing this issue.
Dave
My DOC Welcome Kit
Dave Yeski
Old Jul 4th, 2010, 10:21 am   #6 (permalink)
If you disconnected the pump, then just reconnected it and all was well again, basically, you (apparently unknowingly) isolated the problem fron the connection to the pump.
Dave
my thoughts exactly , thanks dave
Old Jul 4th, 2010, 12:49 pm   #7 (permalink)
Nginear's Avatar
Dave
+1 bad connections can cause high amperage draw.
Maybe water got in the connector and caused a short. Been through rain or washed it recently?
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
Nginear is offline   Reply With Quote
Old Jul 4th, 2010, 7:22 pm   #8 (permalink)
i unplugged the connector and hit it with the compressor so if there was infact some water in there its gone now however i dont think thats the problem
Old Jul 6th, 2010, 4:20 pm   #9 (permalink)
just dropped the bike off to ducati - i hope this dont cost me an arma and a leg and a nut
Fuel pump fuse keeps blowing, help! M5zealot Supersport 14 Jun 4th, 2009 12:28 am
Error 2.1: Pick-up Pressure error fred2602 HyperMotard 13 Feb 17th, 2008 7:55 am
Fuse removal XX9? Nove-R Superbikes 8 Sep 18th, 2007 9:25 pm
ST4 Headlight fuse MarkST Sport Touring 2 Jun 4th, 2007 3:45 am
Which fuse for the 749 headlight? kurtfriedrich Superbikes 4 Apr 19th, 2007 4:47 pm
