Shift-tech Adjustable Pegs - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Jul 2nd, 2010, 9:35 pm   #1 (permalink)
I just installed the adjustable pegs on my hyper. If anyone else has them, did you ditch the spring for the OEM fold-able stock pegs? There really isn't a hole in the shift tech pegs for the spring to attach or rest on. I like them when they were spring loaded, but without the spring I think i am going to constantly have problems.
Stainless65 is offline   Reply With Quote
Old Jul 3rd, 2010, 12:35 am   #2 (permalink)
I have those as well and I used the spring from the stock pegs. Don't remember if there is a hole in pegs but there is definitely something as I installed it with no problems...
sst256 is offline   Reply With Quote
Old Jul 3rd, 2010, 7:19 am   #3 (permalink)
I got it.
Thanks sst256.
Old Jul 5th, 2010, 10:15 pm   #4 (permalink)
couchflyer's Avatar
Images: 54
I installed them with the springs. Its been two years ago and I don't remember any issues installing them.
2008 Hypermotard 1100s
2008 1098
Sola Gratis
couchflyer is offline   Reply With Quote
Old Jul 6th, 2010, 11:20 pm   #5 (permalink)
kedo's Avatar
They install with the pegs. Here's a pointer... grind down the short end of your 5mm allen wrench about 1/4" so you can adjust/tighten the pegs without having to disassemble everything. Carry it with you when you ride. Even with blue locktite, it is good to check the screws.
kedo is offline   Reply With Quote
Old Jul 7th, 2010, 3:55 am   #6 (permalink)
Decreasing Dave's Avatar
Images: 14
Don't you guys still have issues with grinding the brake levers even with these pegs??
We need someone to come up with brake levers that have more bend upwards so that they can be adjusted out of the way.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jul 8th, 2010, 9:43 am   #7 (permalink)
Had to laugh reading about grinding down the allen wrench. That's exactly what I had to do. Wasn't smart enough to put it in the toolkit though (doh!).
Had no problem using the stock springs. All the holes or slots or whatever were right where they were supposed to be.
redscout is offline   Reply With Quote
ST Adjustable foot-pegs from DD tahoest2 Sport Touring 9 Jun 7th, 2010 3:57 pm
Ducati Designs adjustable pegs Activator HyperMotard 4 Feb 23rd, 2010 9:15 am
shift-tech foot pegs feedback ? shanetbird HyperMotard 3 Aug 2nd, 2009 8:09 pm
Adjustable Foot Pegs! MesaDuc Sport Touring 22 Dec 15th, 2008 11:03 am
DIY adjustable foot pegs Mojogoat Sport Touring 8 Oct 13th, 2008 8:59 am
