Clutch Life? - Ducati.ms - The Ultimate Ducati Forum
Old Jul 2nd, 2010, 2:19 pm   #1 (permalink)
Clutch Life?
What is everyone getting for clutch life out of their hypers?
Mine was making a weird noise every once in a while pulling away from a stop so I pulled it apart today. This is my first bike with a dry clutch, but at 11,000 miles the plates look pretty shot to me and the basket looks like its on the way out. Here are pics:
Most the wear plates measured at .115"~2.92 mm, the pack came in at 1.516"~38.5 mm. Going by the manual the plates still have a bit of life in them, but the overall pack is way under spec. What is the new thickness of these parts?
Also, an old motocross trick was to just file the clutch baskets smooth again. Is anyone doing this? What is everyone running for aftermarket clutch baskets?
2008 Hypermotard
2006 RM 250
2001 XR650R
RMZ290 is offline   Reply With Quote
Old Jul 2nd, 2010, 2:32 pm   #2 (permalink)
Corse1's Avatar
Images: 2
Rather than using file on the basket take one steel plate from the back of the pack (should be two together at the start of the pack) and move it to the outside thereby shuffling the friction plates along one position, Now they will be working on the new part of the basket slots.
When I get the "strange" noise I use breakclean on the friction plates and scotchbrite on the steel plates to clean them up. Does wonders!! Factory max clearance tolerance for the gap between the friction tang and the basket slot is 0.6mm or 0.024". Your look a little shot there.
Mine have been at 0.6mm for 6000 mls now due to the quiet clutch mod which also extends clutch life so you change the frictions when they go below the 2.8mm tolerance rather than the when the tangs are beaten to death
Not sure on the pack thickness tolerance off hand sorry
Corse1
03 ST4s ABS (2006 -)
07 Tuono 1000R (2011 -)
03 Aprilia Tuono RSV 1000 Racing (2011-2011 Crashed)
06 1050 Speed triple (2009-2011)
Corse1 is offline   Reply With Quote
Old Jul 2nd, 2010, 2:39 pm   #3 (permalink)
08hyper's Avatar
Yes, you can smooth the tabs with a file, on the clutch basket tabs, this will help the plate movements, for a smoother clutch, but keep in mind that the space gets bigger and will create more noise, and the dents will come back sooner.
I use a Barnett clutch basket, they have stainless steel inserts over the tabs to prevent the "denting" and they run quieter as well. Aloha Alex
Old Jul 2nd, 2010, 6:47 pm   #4 (permalink)
kingsnake1650's Avatar
I havent changed the clutch on my hyper yet but past Ducati's 10-12K is about the mark for my clutches to give up
kingsnake1650 is offline   Reply With Quote
Old Jul 2nd, 2010, 8:48 pm   #5 (permalink)
HYPERR's Avatar
Wow is that normal for Duc clutches? That doesn't seem like a very long time.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Old Jul 2nd, 2010, 10:59 pm   #6 (permalink)
jboothe's Avatar
Idk but I have almost 11,000 miles on mine and yes it makes all sorts of noise.
Old Jul 3rd, 2010, 9:18 am   #7 (permalink)
Looks like there are a few options for replacement.
1- I could just file down the current basket and stick a new clutch pack in it for about $150. Not sure how much life is really left in the basket, I would expect under 6000 miles. The Barnett packs seem to have lots of issues though with fit and slipping.
2-New Pro-cutting basket and Barnett pack for $462. Basket supposedly has tighter tolerances.
3- EVR 48T basket with pack for $459. Can I use this with all the other stock clutch parts and cover?
4-Barnett basket and pack for $345, has the stainless on the edges of the basket to improve life.
The EVR seems like the way to go, times the surface area on the basket for the plates hitting so I would think it would last much longer, not sure on the plates themselves though. Does anyone have any experience with those? I'm just looking for life/cost.
2008 Hypermotard
2006 RM 250
2001 XR650R
Old Jul 3rd, 2010, 9:45 am   #8 (permalink)
acesanugal's Avatar
Holy shit! I've got 23,000 miles on my Hyper, and my clutch looks like new. -Well, it's a little worn, but NOTHING like that. Damn!
Abide.
acesanugal is offline   Reply With Quote
Old Jul 5th, 2010, 4:56 am   #9 (permalink)
IDK if thats normal or not... Its just normal for me. on previous wet clutch bike (r6,r1,zr7) I have pulled about 15K out of the clutch.
I think I tend to be kinda hard on them
Old Jul 5th, 2010, 7:38 am   #10 (permalink)
HYPERR's Avatar
Yeah me thinks you like to wheelie a little?
Current Rides:
2004 Honda CBR600RR
2002 BMW R1150R
slipper clutch pack life ... johnchypermotard HyperMotard 10 Aug 6th, 2009 10:18 am
Clutch life? Stikshaker73 HyperMotard 5 Jun 30th, 2008 7:32 pm
Average 998 Clutch life oakbri Superbikes 3 May 4th, 2008 6:49 pm
clutch life expectancy bobert421 Superbikes 10 Apr 3rd, 2007 1:50 pm
Clutch life under severe service? MarcS Sport Touring 5 Jun 29th, 2006 2:56 pm
