Aussie Hyper Rebuild - Ducati.ms - The Ultimate Ducati Forum
Old Jun 29th, 2010, 4:52 am   #1 (permalink)
MY45's Avatar
Hi guys, its been a while since i have posted here or even done anything to the bike.
Atm its is an 08 1100 Hyper S, Open Carbon Clutch cover, Internals of the clutch have all been painted by me, full Zard Penta system, FatDuc, Zeta hand guards with turn signals and new bars and shaved seat.
There was a build up thread on here once apon a time, ut it seems that we have lost a lot of threads.
Now after seeing hyperstrada77's build thread i am keen to get back into mine, and seeing as though i love the look of his, i plan on doing something very similar.
So i have stripped her down to this and have started playing with the front fender/headlight.
MY45 is offline   Reply With Quote
Old Jun 29th, 2010, 5:04 am   #2 (permalink)
MY45's Avatar
Old Jun 29th, 2010, 5:11 am   #3 (permalink)
MY45's Avatar
Thought id better through in some pics of how she was before hand....
Hahaha thought you'd like to see this one as well
Old Jun 29th, 2010, 7:38 am   #4 (permalink)
londin's Avatar
Always good to see a project build
What mirror is that you have on the bike?
londin is offline   Reply With Quote
Old Jun 29th, 2010, 8:00 am   #5 (permalink)
nickd64's Avatar
Fatduc
Hi MY45
I note in your post you have a fatduc fitted & am keen to hear if it has improved the throttle / fuelling on the hyper? I have considered purchasing one but have only read reports from users in the US. What is your opinion of the device and did you purchase yours over the net from the US manufacturer or locally here in Oz?
regards Nick
Nick - 2008 Hypermotard S
nickd64 is online now   Reply With Quote
Old Jun 29th, 2010, 11:13 am   #6 (permalink)
Nice work so far, thanks for the mention
Are you planning on lowering the headlight a bit, looks a bit high up without the full beak at the moment?
Keep us posted, cheers!!
hyperstrada77 is offline   Reply With Quote
Old Jun 29th, 2010, 12:00 pm   #7 (permalink)
AXE
AXE's Avatar
I like that beak trimmed up the way you did it. Can't wait to see it done.
I see the Hyper build off between hyperstrada77, MY45, sakurama, C2D, and Mangler. We'll set up a vote, maybe get a TV show.
Out!
2008 Ducati Hypermotard
Old Jun 29th, 2010, 5:12 pm   #8 (permalink)
MY45's Avatar
Its just a cheapie from a local bike shop, but it fails horribly as a rear view mirror....did get me through my rego check though
Originally Posted by nickd64 View Post
Hi MY45
regards Nick
Hey Nick, i had major troubles with my throttle being hard to cotrol. low speed corners were a joke, the throttle would be on and off all the time. Installed the fatduc and it improved it alot (it may be running a little rich atm but im not too worried). Then i found a thread on loose throttle cables giving the same problem so i tightened mine right up and all my problems were gone
It was purchased from FatDuc over th net and was super easy to install and adjust once you fiddled with it abit.
Yeah the head light does look too high atm, i will have to do something with it. I quite like the resize/sharpening of the beak, i wasnt too sure how it would look on the bike.
I see the Hyper build off between hyperstrada77, MY45, sakurama, and Mangler. We'll set up a vote, maybe get a TV show.
Out!
Hahaha Biker-Build-Off.ms
Old Jun 30th, 2010, 6:11 am   #9 (permalink)
MY45's Avatar
Had another litle play tonght.
Front headlight has been moved down about 100mm i would guess. I did this by just flipping the standard lower mount and removing the top tab. Then the lower tabs were trimmed a little.
Tabs....
Flipped mount...
Light sitting in lower mount...
Lowered with trimmed beak...
I am thinking that it is still abit high, but i will leave it like that for now and see what it looks like after the tank is done.
Also had a little play with seat and subframe heights with an old DR650 seat i had sitting in the shed. I dont plan on using this seat as the front angle is too steep, but i dont plan on going to a real thin moto x seat either as i still plan to do some long rides on it. Ill nead a seat that i can sit on for 2-3+hrs.
Old Jun 30th, 2010, 9:57 pm   #10 (permalink)
merovingian's Avatar
Wow gettin' right into it good to see, looking forward to updates.
Planning on sticking with the Zards?
merovingian is offline   Reply With Quote
Hi from another Aussie Hyper Owner! Pop HyperMotard 22 Dec 13th, 2009 5:11 am
Any other Aussie with their Streetfighter? WAY StreetFighter 11 Aug 18th, 2009 2:05 pm
Need some Aussie help! Riderjeff Sport Classic 8 Apr 3rd, 2009 9:11 pm
Aussie aussie Sport Classic 10 Jun 19th, 2006 2:14 am
