The black plastic part the fuse plugs into. Does this happen everytime? Is that the solenoid switch that fuse is mounted too? Maybe your solenoid is some how staying activated causing excessive heat
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
