how to remove the service wrench - Ducati.ms - The Ultimate Ducati Forum
Old Jun 21st, 2010, 7:11 pm   #1 (permalink)
Ive got the VDST software and Im trying to clear the wrench symbol off my dash with no luck..any thoughts on this
2005multi is offline   Reply With Quote
Old Jun 22nd, 2010, 7:28 am   #2 (permalink)
PKM
Can't tell from your post if you can't find the reset function in the VDST software or if it is simply not working for you. If the former:
1) Select "Active Settings" (the blue screwdriver thingy).
2) First tab in Active Settings is "Erase" and shows "Clear DTC" and "Maintenance Light" options. Select "Maintenance Light", say "Yes" to continue, and erase (reset) wrench.
Hope this works for you!
Ride Safe.
PKM is offline   Reply With Quote
Old Jun 22nd, 2010, 12:38 pm   #3 (permalink)
Ride Safe.
Tried that...no worky...
Old Jun 22nd, 2010, 7:38 pm   #4 (permalink)
Don't know if this helps but from what I have read VDST software does not work on the 2010. Not sure what year you own but I thought it was worth mentioning.
reefkpr is offline   Reply With Quote
Old Jun 22nd, 2010, 7:49 pm   #5 (permalink)
doon's Avatar
You should get some sort of message saying connecting with ecm!
Then go about clearing the spanner.
The first time I did it it took a few goes.
doon is offline   Reply With Quote
Old Jun 26th, 2010, 11:32 am   #6 (permalink)
Nginear's Avatar
Your right on. My dealer couldn't even remove the wrench. He said the same thing yesterday that until the new software comes out I just have to live with the wrench being on the dash. Doesn't bother me, but you would think if you are selling something you would have the tools already there to service it.
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
Nginear is offline   Reply With Quote
Old Jun 26th, 2010, 11:54 am   #7 (permalink)
Fin_Duc's Avatar
Nginear: Tell your dealer to go into it as it was a 696 Monster, it has the same Siemens electronics. Thatīs how I did mine anyways..
2010 Dark HM796 w. SC-Project slipon, LV cat elim. and PCV = FUN!!!
Originally Posted by 1badduck View Post
My hyper brings out the hooligan in my hooligan.
Fin_Duc is offline   Reply With Quote
Old Jun 26th, 2010, 11:58 am   #8 (permalink)
Nginear's Avatar
Thanks, Next time I'm down by them I'll try that.
'10 hyper 796
'03 TTR-125
uh oh.... Wrench light came on on dash? i JUST had 6k service.. eingeist Superbikes 16 Apr 12th, 2010 4:04 pm
Are you guys just using an allen wrench to remove your 2ndary oil filter? 3stephenD Sport Classic 15 Apr 29th, 2008 1:46 pm
What size socket/ wrench do I use - Service Caps ? rapter Superbikes 4 Feb 21st, 2008 6:57 am
Service "Wrench" Icon slowpoke HyperMotard 7 Oct 7th, 2007 5:29 pm
When does the service wrench come ON, on the 999R? 2fasst Superbikes 4 Jun 7th, 2007 2:30 pm
