Need help!!! engine problems - Ducati.ms - The Ultimate Ducati Forum
Old Jun 11th, 2010, 10:16 am   #1 (permalink)
I got a Bimota DB6 (it use same engine as Hypermotard) and I don’t know how the sand get into the engine, there are many scratches on the cylinder wall and it is loose a lot of the compression.
Seems I may need to replace both cylinders and pistons. Does anyone know where can I purchase it? Or, are there any other way I can fix the engine w/o replace it?
Many thanks
Stv
beear is offline   Reply With Quote
Old Jun 11th, 2010, 2:55 pm   #2 (permalink)
scratches
just rebore the holes and put new o-rings
Hyper1
HYPER01 is offline   Reply With Quote
Old Jun 11th, 2010, 4:39 pm   #3 (permalink)
johnchypermotard's Avatar
strongly suggest NOT using o-rings ... piston rings will work much better, and last a lot longer
Old Jun 11th, 2010, 4:51 pm   #4 (permalink)
Revelstoker's Avatar
Many thanks
Stv
Sounds like you might be a good candidate for one of these: http://www.ferracci.com/store/cart.p...t_detail&p=756
or this one
http://www.desmoworks.com/index.php?...roducts_id=524.
Revelstoker is online now   Reply With Quote
Old Jun 11th, 2010, 4:55 pm   #5 (permalink)
Originally Posted by Revelstoker View Post
This kit needs to be used with the NCR billet stroker crankshaft and titanium rods for great reliability. Contact us for more information on building a high horsepower Ducati motor.
And the bill goes from 1995$ to almost 10.000$... lovely NCR parts.
Old Jun 11th, 2010, 8:04 pm   #6 (permalink)
08hyper's Avatar
Many thanks
Stv
Get yourself some new pistons, stock or high compression, and send them with your cylinders to (U.S. chrome) www.usnicom.com they will rebore & re-plate them at a fraction of the cost of the new ones. Tell them Alex from OZ engineering sent you. Aloha Alex
Old Jun 15th, 2010, 9:13 am   #7 (permalink)
Thanks lot Alex.
If I rebore the engine, will that increase the diameter of the cylinder? Can the original piston keep it air tight?
Old Jun 15th, 2010, 9:22 am   #8 (permalink)
The NCR kit does looks very sweet, but it is a bit out of my budget.
If you know where I can purchase the original pistons and cylinders kit and that will be great appreciate.
Many thanks
Stv
Old Jun 15th, 2010, 2:01 pm   #9 (permalink)
08hyper's Avatar
Thanks lot Alex.
No, they just bore out the plating, and re-plate the cylinder to your piston size, thats why they need your pistons.
Now if you want to go "big-bore" you can get some 100mm Pistal pistons, (I got mine from the Ducshop) www.ducshop.com product# 84R60A0000 and they can bore the cylinders & re-plate them to the larger pistons for an additional cost. Aloha Alex
DB2 engine problems anatak Bimota 5 Feb 1st, 2010 5:23 pm
Engine problems GR916 Superbikes 5 Jun 24th, 2009 12:13 am
Monster S2R1000 - engine problems at 6K... Ducman2 Monster 13 Jun 21st, 2008 11:29 pm
Severe engine problems! desmo916 Superbikes 21 Apr 2nd, 2007 7:32 pm
Potential engine problems w/ slip-ons as opposed to a half-system on 999? kabinski Superbikes 1 Jan 22nd, 2006 2:33 pm
