While I was at DP Motorsports talking to Eric (Certified Hypermotard Mechanic) he said that the Evaporative Emissions Canister could assist in making the Hyper run lean and I should remove it... while I was tinkering on the bike today Shelby and I decided it was time to go!
If you follow the hose from the evap canister to the right side of the bike you can see where it connects to the barbed fitting on the intake. Use needle nose pliers to remove the clamp and pull the hose off...
On the left side.... same thing just remove the clamp and hose from the barbed fitting.
I carefully pulled the hoses off the bike
I then cut the hose from the fuel tank vent... I couldn't figure out how to release the stamped clamp....
The canister just slide out of the mount by release the clip at the top... then I removed the mount
