Weight Reduction - Ducati.ms - The Ultimate Ducati Forum
Old Jun 4th, 2010, 7:23 pm   #1 (permalink)
NYSport's Avatar
Images: 4
Weight Reduction
Well I've removed the flapper valve motor and assembly, cat was replaced with a Termi pipe. I removed the passenger pegs and stock exhaust system, I just ordered an aluminum subframe. I've pretty much done what I can to lighten the bike. Well now the Hyper has kicked-in with a weight reduction program of its own, shedding nuts and bolts, one at a time, from various locations. Despite my diligence, inspecting and tightening all the bolts and nuts I can reach I still find open holes, void of the factory installed hardware.
Anyone have a good source of "factory" quality bolts. Currently I need belt cover bolts.
Old Jun 4th, 2010, 7:37 pm   #2 (permalink)
johnchypermotard's Avatar
a great source for factory (and even higher) quality hardware, is: http://www.olander.com/
Old Jun 4th, 2010, 9:47 pm   #3 (permalink)
lelenb's Avatar
Images: 12
You have more weight to lose with a Nichols 9 oz flywheel vs 4 lbs stocker and a Speedcell SBK battery for almost an 8 lbs saving. So 11 lbs for roughly $500.
Also on my KX500 I dip my bolts in RTV silicone and the bolts stopped shedding a long time ago. And a two stroke 500 has way more vibration then the Duc. The RTV dampens vibration and has minimal impact on fastener torque.
Lelen
Hyper S
Old Jun 5th, 2010, 12:15 am   #4 (permalink)
disgo duc's Avatar
Images: 23
you can also go lightech or pro bolt they both also have titanium and alloy as well in various colors...so you can add color and lose weight at the same time.
disgo duc is online now   Reply With Quote
Old Jun 5th, 2010, 8:04 am   #5 (permalink)
NYSport's Avatar
Images: 4
Good idea, I'll give it a try.
Old Jun 5th, 2010, 11:38 am   #6 (permalink)
Decreasing Dave's Avatar
Images: 14
Not to mention that the minimized weight of the new flywheel will make the bike feel even lighter than it is.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jun 5th, 2010, 1:46 pm   #7 (permalink)
Raiden's Avatar
After you get the battery and flywheel you should buy a titanium frame from NCR. You'd be the man
2008 HM1100S
Raiden is offline   Reply With Quote
Old Jun 5th, 2010, 7:14 pm   #8 (permalink)
AXE
AXE's Avatar
Your local Ace Hardware store will have more bolts, nuts, and such than most places. They have all sorts of stainless allen head bolts to fix up the holes in your Duc and make it look good too.
Out!
2008 Ducati Hypermotard
Old Jun 5th, 2010, 8:49 pm   #9 (permalink)
NYSport's Avatar
Images: 4
Out!
Cool.
Old Jun 5th, 2010, 8:50 pm   #10 (permalink)
NYSport's Avatar
Images: 4
Titanium frame, yea that's the ticket.
Weight Reduction Gow Supersport 62 Dec 8th, 2010 5:42 pm
Ducati 999R racebike weight reduction JohnMH Superbikes 20 Oct 20th, 2009 5:11 pm
Clutch Lever Effort Reduction Treadmarks HyperMotard 22 Aug 13th, 2009 7:06 pm
Flywheel weight reduction program dietrichpfeifer Sport Classic 32 Jun 8th, 2008 11:07 am
Weight reduction kever888 Sport Touring 23 May 11th, 2006 8:20 am
