K&N oil filter problems? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jun 1st, 2010, 9:33 pm   #1 (permalink)
bullet3z's Avatar
Anyone ever have any or know of any problems with K&N oil filters leaking oil everywhere? Not just on Ducati's but on any bike?
bullet3z is offline   Reply With Quote
Old Jun 1st, 2010, 9:37 pm   #2 (permalink)
No, but I have had the handy little socket come off....
Johno51 is offline   Reply With Quote
Old Jun 1st, 2010, 9:50 pm   #3 (permalink)
HYPERR's Avatar
Yes that happens when you put too much oil on it.
The only bike I have currently with a K&N is my BMW R1150R and I always notice a tiny oil puddle underneath right after I clean and oil the filter.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Old Jun 1st, 2010, 10:23 pm   #4 (permalink)
AXE
AXE's Avatar
He is talking oil filter, you are talking air filter............at least it appears that way.
I have used several K&N oil filters on at least three different bikes and never had any issues. The reason I buy them is because of the nut on the end and you can torque them proper torque wrench. If you overtighten any filter, you run the risk of tearning, compressing, or wrinkling the rubber gasket it can cause a leak. You would be surprised how little torque is used to seat a filter properly according to mfg specs.
Out!
Old Jun 1st, 2010, 11:04 pm   #5 (permalink)
HYPERR's Avatar
Out!
Hehe you are right AXE. My bad.
I actually just happened to use K&N oil filter for the first time on my CBR600RR and I have not had any problem whatsoever. And yes the nut is very nice. Yeah the torque spec is very low. Pretty much hand tight.
Current Rides:
2004 Honda CBR600RR
2002 BMW R1150R
Old Jun 2nd, 2010, 6:54 pm   #6 (permalink)
bullet3z's Avatar
Yes I was talking about the oil filter.
I just helped a friend change his oil on his 06 CBR600RR. I did tighten it down with a wrench but not superman style. It is very hard to get you hands to the filter on a CBR. Anyways he left and about 15 to 20 miles into his ride it started spewing oil all over the place. Lucky for us he was at a red light when it happened.
So is this common for these filters? I have never had a filter do this before and I have changed a lot of oil over the years. On many different types of vehicles. This is however the 1st time I used a K&N. More than likely the last too.
Old Jun 2nd, 2010, 7:12 pm   #7 (permalink)
NYSport's Avatar
Images: 4
No problems here, dry with 3300+ miles on the current filter.
Old Jun 2nd, 2010, 8:29 pm   #8 (permalink)
08hyper's Avatar
The K&N filter oil filter is as good and better than most other oil filters, I'll bet when he took off the old oil filter, the sealing rubber ring from the filter may have stuck to the motor, and when he installed the new one there was now a "double" gasket, which can hold for a while until they slip apart, then spewing oil, a employee of mine did just this to his van, and it cost him an engine. Aloha Alex
Old Jun 2nd, 2010, 8:30 pm   #9 (permalink)
I never had an issue with a K&n oil or airfilter, lways fit perfect and do teir job well.
I would tell you to just double check that the rubber ring from the previous filter was actually removed and you didn't install the K&n over top of the old one, that happens and can lead to your exact problem, check it out... just a thought.
mwtrogus is offline   Reply With Quote
Old Jun 2nd, 2010, 9:03 pm   #10 (permalink)
freezer16801's Avatar
the last two that I had to replace, I couldn't remove using the nut. It sounds as if I am overtorqueing the filter by the advise of other responses. I never have any problems using them on my R6 track bike. They are very nice running safety wire too also.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
996 air filter help thedjmongoose Superbikes 2 Apr 28th, 2009 1:04 am
Oil Filter 999 zbomb Superbikes 11 Sep 10th, 2008 10:32 am
a whole mess of problems..but i'm thinking the problems are from one source 1998duck Superbikes 7 Sep 8th, 2008 4:17 pm
Air Filter PeteST4 Sport Touring 2 Aug 23rd, 2008 7:07 pm
help with oil filter ny749 Superbikes 7 Jun 1st, 2007 2:59 pm
