Hyper S Rims - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jun 1st, 2010, 8:17 pm   #1 (permalink)
CounterSteerer's Avatar
Hyper S Rims
I have cash to trade for Hypermotard S, S4RS rims......
Scratches OK, Bent not interested.
CounterSteerer is offline   Reply With Quote
Old Jun 1st, 2010, 8:24 pm   #2 (permalink)
Crank1000's Avatar
I may be interested. Mine are mint, how much are you offering?
Old Jun 3rd, 2010, 1:48 am   #3 (permalink)
kedo's Avatar
Don't you want to post to the WTB Classified's? Just a suggestion. Cheers.
kedo is offline   Reply With Quote
Old Jun 3rd, 2010, 9:36 am   #4 (permalink)
I did recently post in the classifieds for a S rear wheel and pretty much got no answer...
Well I did get 2 answers in fact, a private message saying "maybe" but then never came back, and an offer for 550euro. By the time I would go for it, the seller took a step back.
Unlike the front forged wheel that you can take from a 1098S / R or even a StreetFighter S, the only bike with a rear 10 spoke forged alu that fit the Hyper is... the Hyper S.
I believe he will have way more visibility posting here than in the classified section.
But it's a long shot. You need to find a Hyper S owner who upgraded to magnesium or BST.
Old Jun 3rd, 2010, 10:16 am   #5 (permalink)
jboothe's Avatar
Is there a cross reference for what will fit a Hyper front and rear/with or without modification/materials/spokes/etc somewhere? That would be really cool. I have been looking for another set to be able to have a set of street tires on one and track tires on another but the cost is just stupid. I have seen some sets for other Ducs on ebay and thought maybe they would fit but I can't ever get anything definitive.
I don't really care if they are cast or forged or magnesium but I can't justify $2000+ for extra rims than another chunk of cash for front rotors...
Old Jun 3rd, 2010, 11:19 am   #6 (permalink)
Pretty much every front wheel will fit the HM. You just have to make sure it's a 5 bolts for the brake rotors.
HM Multi 1098 848 S4R S2R S4RS.
The rear wheel is a little bit different.
I could forget some options, but basically HM 848 S4RS
Standard and 848 wheel set usually go on ebay for a 1.000$, and I think it's the cheapest way to go if you want an extra set for the track.
Old Jun 3rd, 2010, 12:57 pm   #7 (permalink)
jboothe's Avatar
Thanks for info. That does help. Do you know if there are some different rotors offsets depending on application for the front? I thought I read that somewhere but it may have to do with older models.
Old Jun 3rd, 2010, 8:06 pm   #8 (permalink)
Most pre 2007 Ducati front wheels have 6 mounting holes for the brake rotors. 5 hole rotors are on these pre 2007 models: 999 and 749. Newer models with the 5 hole mounting seem much more common... M696, HM, 1098, 848, S4Rs, `07+ S4R.
Given how much change Ducati has been through lately, I wouldn't trust that parts interchange as easily as they did before.
The HM rear wheel seems to be the same as almost all non-1098 single sided rear wheels: 916/996/748/998, MTS, S2R, M1100, 848
Front wheel though, you've got to be careful of 2 variables... rotor offset and rotor mounting holes. Before the recent bikes HM, 1098, M1100, etc... almost ALL non 749/999 front wheels from 2000 on were interchangeable. All had 6 holes and 5mm offset. The 2 exceptions were the 748R and the 996Corse, which were 6 hole but had 10mm offset.
So before swapping out the HM's front wheel, you need to fond out the spacing between the rotors on the wheel itself...
-Chris
California Cycleworks, Inc
www.ca-cycleworks.com
619/501-2466
chris_k is offline   Reply With Quote
Old Jun 4th, 2010, 8:57 am   #9 (permalink)
edited
Alloy rims vs black steel rims? IN2VWS Sport Classic 48 May 3rd, 2011 6:42 pm
BST rims 1198freak Superbikes 49 Dec 2nd, 2009 9:10 pm
rims claytonpratt Superbikes 5 Oct 16th, 2009 1:49 am
Hyper rims in a 748R desmo_pt Superbikes 1 Nov 5th, 2008 3:33 pm
996 rims the-duc-master Superbikes 1 Mar 6th, 2007 5:04 pm
