Originally Posted by 2005multi
Can this thing be removed? Im thinking its the reason for the wisspy exhaust note thru my zard slipon
Yes, it can and should be removed (weight/airflow/sound, etc). A full system, like the Zard collectors, replaces the stock "S" pipe and removes the flapper valve assembly entirely. If you don't have a DP ECU (from 2-1 or 2-2 Termi kit), you will get a DTC error after you remove the butterfly valve - motocreations offers a reasonably priced solution, which fixes the CEL error and lets you remove the funky actuator thingy under the seat :
http://www.motocreations.com/electrical.asp
If you have a DP ECU, the butterfly valve is already inactivated and you shouldn't receive an error code after it is removed.
