Difficulty getting neutral - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old May 25th, 2010, 9:09 pm   #1 (permalink)
jethro911's Avatar
So I finally got the Hyper on the road after the rebuild. The bike has only a few hundred miles on it and for some reason it doesn't like going into neutral when the engine is running. It goes in just fine if you shut the engine off but is damn near impossible when running. It shifts fine through all the gears and is running perfect otherwise.
Any ideas?
jethro911 is offline   Reply With Quote
Old May 25th, 2010, 9:57 pm   #2 (permalink)
Any ideas?
try bleeding ur clutch..from master to slave..sounds like a stubborn bubble
2005multi is offline   Reply With Quote
Old May 25th, 2010, 10:11 pm   #3 (permalink)
Monstaman's Avatar
...and to assist bleeding set your clutch lever to the farthest out setting so you get the max throw on the piston to chase the bastid bubble out.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old May 26th, 2010, 5:56 am   #4 (permalink)
Banned
Images: 19
Really good advice from these fellaz...
So give us the guff on the rebuild jeth...and why...?
I aint been here long so forgive my ignorance...
Tard is offline   Reply With Quote
Old May 26th, 2010, 8:58 am   #5 (permalink)
hyperdookie's Avatar
Images: 9
This may help if it's really stubborn.help with evr slave!
Due to the location of the bleeder on the slave, it can be difficult to purge all of the air out.
Old May 26th, 2010, 8:24 pm   #6 (permalink)
jethro911's Avatar
No problem, the bike was low sided on the left side by the PO who we believe may have perished in the accident but we aren't sure. The damage wasn't bad just scrapes really but it meant new bars and guards as well as a sub frame and swingarm etc etc which adds up. No marks on the engine cases at all and even the shifter was fine so I doubt the accident is related to the issue at hand but then again machines can do strange and unexpected things when bumped hard.
Removing the swingarm: difficulty? number9 Supersport 25 Mar 22nd, 2009 3:02 pm
difficulty starting an 02 998 Bill998 Superbikes 20 Oct 2nd, 2008 9:25 pm
Difficulty entering Neutral - did I screw up something ? VRlife Sport Touring 7 Jun 22nd, 2008 12:20 pm
Difficulty in Changing Levers? Kramer Sport Touring 8 Dec 2nd, 2007 12:23 pm
Difficulty Shifting Sig Sport Touring 7 Apr 30th, 2006 9:13 pm
