Some VDSTS data/
So, i installed a 708b DP ECU in conjunction with my Zard TOPGUN slipons, then used the vdsts software to reset the TPS and adjust the trim. Though that process was pretty straight forward not sure what all the other data ive gathered means. was hoping i could get some input on whether or not the other values are ok...The trim is set at +5 and at idle the throttle pos. is at 3.1...spark advance is at 2.2 and injection time is 2894...any thoughts would be appreciated
