May 17th, 2010, 7:54 pm
Bigger rear tire for the hyper??
Hey guys any Hyper owners running 190/50/17 on the rear? I found a new set of PPCT2 for cheap...just wanted to know if the bigger rear tire would give me some clearance issues??
"Currently in the stable"
08 1098S Red
08 Hypermotard 1100
09 Monster 696 Dark
09 Monster 696 Pearl
07 Monster S2R1000
06 Repsol CBR1000RR
07 GSX-R 750 "custom paint"
08 Kawasaki Ninja 250R "wifeys"
05 KTM 525 SMC Supermoto
73 Kawasaki Z1900 "Still FAST!"
06 Kawasaki KX450F
03 Indian Chief Roadmaster
May 17th, 2010, 9:59 pm
I believe you can run a 190 fine as far as clearance goes, not sure how badly it would affect handling though assuming you're installing it on the stock 5.5" rim.
May 17th, 2010, 10:10 pm
Extended Member
I have a 190 on the rear... thought it looked cooler. I can't tell that it has affected clearance or handling and I tend to lean the hyper over pretty hard. you can put it on the 5.5 rim same way ducati did for the 749 and 999 .
May 18th, 2010, 8:43 am
Thanks for the input guys...Man, I like those Gold wheels Alexio!!
08 1098S Red
08 Hypermotard 1100
09 Monster 696 Dark
07 Monster S2R1000
06 Repsol CBR1000RR
06 Kawasaki KX450F
May 18th, 2010, 11:30 pm
Just found me a good deal on a 190...hope you guys are right!!!!
Greg aka Motoman
www.emotoman.com
2009 Duc Hyper S
2006 Honda CRF50
2005 Suzuki LTZ-400
2005 Honda CRF450x
2003 Yamaha YZ250F
1993 Sportster Hybrid
1977 Kawasaki KZ650
May 19th, 2010, 12:39 am
You might want to check with Cycle Gear, but last weekend they had a $199 package deal on a set of Dunlop Sportmax Q2s. You can get any size you want.
Out!
2008 Ducati Hypermotard
May 19th, 2010, 3:48 am
Banned
With a 190 your only gonna get an extra 5mm each side compared to a 180, which is hardly noticeable visually. (About a 1/4 inch for you imperial folk).
It may affect your turn in, if your racing, but I doubt you notice it on the street. (depending on tire shape)
It's illegal now to run a 190 on a 5.5" rim here down under, thank God there's no tire police, yet it's OK to run a 180 on a 6" rim, (which is probably worse), like the Ape's do on the Shivers, Dorso's etc... weird.
We've been running 190's on 5.5" rims since Noah was a boy, without probs...
You'll have room easy...unless you have a rear huger that really hugs
If you feel the need for enlargement  then go for it...
I'm still interested in the Dunflop Q2s. Heard good things but I'm a Pirelli fella from way back so...
May 20th, 2010, 8:41 am
I've been running a 190 on mine now for 4 months with a rear hugger. No clearance problems whatsoever. Seems to give more traction but yes it slows the cornering speed slightly but you really only notice if you're going hard.
Life without my motorcycle is no life at all.
May 20th, 2010, 9:35 pm
Yeah...I passed on that 190 PP2CT deal. I don't want to screw up the handling, she corners real sweet right now even on bald tires! I'm going to run with the 180 Dunlops Q2. Heard good things about these dual-comp. tires "real sticky" & can't beat Cycle Gear deal $199.00 for the pair. Anyone else running the Sportmax Q2??
08 1098S Red
08 Hypermotard 1100
09 Monster 696 Dark
07 Monster S2R1000
06 Repsol CBR1000RR
06 Kawasaki KX450F
