What size bolt to plug O2 sensor in Termi 2-1? - Ducati.ms - The Ultimate Ducati Forum
Old May 17th, 2010, 6:52 am   #1 (permalink)
Dana's Avatar
Images: 28
Installed 2-1 full Termi system and need to plug the O2 hole. What size bolt?
Thanks!
Dana
'08 Hypermotard 1100S
Dana is offline   Reply With Quote
Old May 17th, 2010, 10:30 am   #2 (permalink)
hyperdookie's Avatar
Images: 9
Thanks!
Dana
As far as I know,you shouldn't have a hole for the O2 sensor on the Termi 2-1. The system eliminates it. The system does have two plugs, one on each cylinders header pipe. These holes are for "sniffing" with a gas analyzer to balance the CO% on each cylinder individually. The plug is 10x.9mm. This is an odd thread pitch and probably not available in your local hardware store. Unfortunatley I don't know where to soure them but someone here might.
(edit)Now that I think about it, just transfer the plugs from your original system. If your 2-1 does for some reason have a hole for the O2 sensor, it's 18x1.5mm.
Old May 18th, 2010, 3:46 am   #3 (permalink)
Dana's Avatar
Images: 28
Good call Dookie!
It wasn't the O2 sensor but the bung for the sniffer. I stole the two off the stock pipes and viola!
Thanks bro!
Dana
Old May 18th, 2010, 8:45 am   #4 (permalink)
Images: 9
Thumbs up
Good call Dookie!
Thanks bro!
Dana
Haha... you said dookie bung sniffer in your post.
Sorry, that was childish.
Enjoy the pipe!
Old May 18th, 2010, 11:09 am   #5 (permalink)
Decreasing Dave's Avatar
Images: 14
Enjoy the pipe!
Haha.....you said "Enjoy the pipe" in your post.
Not that there's anything wrong with that.....
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old May 18th, 2010, 4:39 pm   #6 (permalink)
Images: 9
Thumbs up
Dave
Touche'...I see you are childish as well. Not that there's anything wrong with that!
Old May 19th, 2010, 12:35 am   #7 (permalink)
AXE
AXE's Avatar
If you run some other systems, the O2 sensor bung is 18 mm if I recall. At least it is on the Zard. Some people's system just have a large bung hole.
Yeah, I said large bung hole.
Out!
2008 Ducati Hypermotard
o2 sensor plug after removal xrmoneypit HyperMotard 7 Mar 24th, 2010 7:11 pm
Termi 2-1-2 baffle allen bolt size? Borracho HyperMotard 2 Jul 20th, 2009 5:46 pm
02 Sensor Plug nwrob HyperMotard 0 Sep 12th, 2008 5:07 pm
O2 sensor plug c-man-of-md-x Sport Classic 1 Aug 16th, 2007 7:53 am
Anyone have an O2 sensor plug??? ThunderDucRacer Sport Classic 0 May 10th, 2007 4:13 pm
